Scooter indicated it is fully charged it powers on but will not turn over to run
SOURCE: After a period of use the Scooter turns itself off.
sounds like it might be a bad throttle pod, or the brake is overheating. If you can pull the rear shroud off and drive it for a while you can check to see if the brake is overheating. Be careful when checking it because if it is really hot it will burn your fingers. The throttle pod can be checked with an ohm meter but i'm not sure off the top of my head what reading you should get. let me know if you would go that far and i'll get it for you.
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
SOURCE: Travel Pro Scooter charging problem.
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
