20 Most Recent Razor Crazy Cart Electric Ride On Pink Questions & Answers
Try battery first check with digi. volt ohm meter, but yes it could be module.
Razor Crazy Cart... | Answered on Jan 26, 2016
Do you mean the Panasonic ES-RT51-S razor? The manual for this razor is on the product page: http://shop.panasonic.com/personal-care/mens-shavers-and-grooming/mens-shavers/ES-RT51-S.html . Scroll down to the Owner's Manual in the Support section. The direct link to the manual is ftp://ftp.panasonic.com/shaver/om/es-rt31_en_om.pdf .
I hope this helps.
Razor Health &... | Answered on Aug 29, 2017
PCassels Check the brake located on the rear of the motor. If the brake is dragging on the motor housing it will cause heat and slow the scooter down. If you can, remove the brake from the motor but leave the wires connected. Tie the brake up so it won't fall and see if that makes a difference in speed and heat reduction. Don't overcharge the batteries Charge overnite or until the green light on the charger comes on indicating a full charge. Never charge more than 10 hours for this scooter. Now with the brake not on the motor the scooter will not have brakes so watch out on ramps and steep inclines. If it is only a few months old then it is still under warranty and you need to contact the provider that sold the scooter to get it repaired correctly Hope this helps
Razor Health &... | Answered on Nov 18, 2010
To have a good motor and battery follow these easy steps...
1. Take MX500 out of box CAREFULLY!
2. Assemble in order of the directions (If you follow them it will be assembled in 20 minutes).
3. Turn MX500 on and JUST FOR ONE SECOND TWIST THE THROTTLE just to make sure it works. (Do not ride just a flick of the throttle just to check).
4. Charge the MX500 overnight or for 12 or more hours (The key is to charge it for 12+ hours)
5. Take the charger out and go ride
If you follow these directions given your MX500 will be perfect.
If you did not follow this direction your motor cycle will have problem.
Change motor change controller it could be the battery so change the battery.
Thanks for using Fixya.
Razor Health &... | Answered on Jun 25, 2010
Razor Crazy Cart Electric Ride On Pink Logo
2 questions posted
Top Razor Health & Beauty Experts
Tom Chichester
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Razor Health & Beauty
Most Popular Question
crazy cart run
  • Health & Beauty
