Hi i, i've got a lg ld 14aw2 dishwasher it turns on but when you push the start button it will not start it just beeps
Most likley problem is the door is not closing properly or the door latch switch is faulty. This means the dishwasher controller is not getting the right signal before commencing the wash cycle.
Need to check the closure of the latch. If this is ok then replace the door switch.
View the door panel diagram, schematics and parts in this site
http://spares.bigwarehouse.com.au/index.php?cPath=24759_25855_26296&sort=2a&page=1
SOURCE: LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections. .water is leaked by damages hope this helps, keith
SOURCE: LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
SOURCE: LG dishwasher model LD-14AW2 comes
I took the side panel off and found the start capacitor for the pump motor burnt out.I purchased a new 5 uf capacitor for $9 and installed it.
Regards Neville OBrien
SOURCE: LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
Remedy:
SOURCE: I have a LG LD-14AW2
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I had a similar thing. Every time I went to
start the dishwasher it went "Ding Ding". I could press every button,
turn it on and off OK, change cycles etc. I guessed the sound maybe because it
thought the door was open, so set to work pulling it apart. This is how I fixed
it.
Make sure you do most of this with the power off - there is probably mains
voltage inside!
After pulling off the the cover of the door (with the door open, undo about a
dozen screws), the front will fall off if you don't hold on to it, and the door
swing closed, so be careful. When it has detached, move the metal part aside,
and place the "brains" (circuit board etc) on to a chair or similar
so the wires don't stretch.
A quick way to see if you have the problem is the same as mine is to remove the
orange cable from the PCB as per below:
Turn the power back on, and press the power button, then the play button,
things will hopefully work. If they do, turn it off right away and continue as
per below to fix. If you are not worried about the safety mechanism - you could
just leave it off and put things back together. However if you forget I think
the entire kitchen could get very wet!
Reconnect the orange cable, and start by removing the handle. You will need to
disconnect the cable block going in to the back of the handle mechanism, and
remove the 3 screws as shown:
Once you have the handle off, remove the metal cover. I found I had to slide it
down at an angle and back, ie:
With that off, you should then be able to carefully edge out the reed switch -
this is the source of the problem. In the image below the arrow point to TWO
hooks that need to be released as you slide it out. I found that the hooks got
stuck on the seam as well, so go slowly.
Once you have the reed switch out, you can see if the local electronics shop
has one the same (probably the best long term fix), or if you pry it apart, I
lightly scraped the contacts inside it:
Once this was done, I could put the handle back together and test (I tested
before putting the whole front back on). With a screw driver you can put the
mechanism back to "close" the door, and things should hopefully work.
Or to "open" the door, pull the handle, and use the screw driver to
pull it the rest of the way, ie:
Once you are happy it is all working, put everything back together and things
should hopefully be away!
