Toshiba Satellite Pro L300 Notebook Logo
A
Anonymous Posted on Apr 20, 2014
Cannot load windows or install windows 7 - Toshiba Satellite Pro L300 Notebook
alibaba69
Level 3:
Master:
  • Master 490 Answers
  • Posted on Mar 24, 2016
alibaba69
Master
Level 3:
Master:
Answers
490
Questions
Helped
186627
Points
1312
Insert boot able win 7 DVD and reboot, follow onscreen instructions..done
I cannot load creator7 5 in my 64bit windows 7 cumputer
If u have windows 7 64bit load in cd or dvd rom this cd and install wnidows7 64 bit before installation u r format u r c drive and then install it and re install u r all software enjoey
tip
INSTALLING A PRINTER IN WINDOWS 7
To install a printer in window 7, you need the printer installation CD/software.
Connect the printer to your system via a USB Cable (or any other cable necessary). Power on the printer. If you use a USB cable, windows 7 will automatically detect the printer and try to install it for you. However, if windows 7 does not have the driver, you will be prompted to load the drive from CD or a file location. If you have the Driver CD, load it now or browse to the folder where the driver software is located and load the software. Follow the on screen instruction to complete the installation.
Also
From start------devices and printers ------ add a printer ------add local printer ----- use an existing port, next ----------choose the printer manufacturer and the printer model. If not on the list and you have the installation CD choose have Disk and then next. Follow the onscreen instruction to complete the installation.
You can also run the Printer driver software and follow the onscreen instruction to complete the installation.
on Jul 01, 2010 • Computers & Internet
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
What's your problem?- CANT LOAD WINDOWS 7 ON LATITUDE E6420
it comes preinstalled with windows 7, what error message are you receiving while attempting install? if you mean it doesn't load the actual OS after booting, what error are you getting? does start up repair attempt to run?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
4helpful
Driver Canoscan N670U for windows 7 64-bit
Free option to use CanoScan N670U wth Windows 7 64 bit
VueScanner cost$ --> I am running Windows 7 64bit and was able to use my CanoScan N670U by Installing Windows XP Mode in Windows 7 at no additional cost
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
After install the software loaded and the only trick was to click the "USB" dropdown in the virtual machine menu at the top of the screen and select canoscan
I have duall opreating system. One is xp another one win7.When i format my laptop.than load first xp-32bit.Than i load win 7.after finishing all the win-7 instlation.restart the system than i feace the...
Hi.
The "tfght" message means that some of the files, folders and sub folders are compressed.
Boot the Windows 7 DVD, choose Custom install, on "Where do you want to install Windows" screen, click on Load Driver. Now use the mini-explorer which pops up to rightclick on System HD then choose Properties. Uncheck "Compress Drive to save Disk Space" for All Files and Sub-Folders. Restart.
That should solve the problem.
However you may have to start again. Click on the link below for an in-depth guide on how to dual boot XP and Windows 7.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html?ltr=D
Good luck and regards.
1helpful
Formatted acer aspire 5736z with windows 7 ultimate and finished but operating system not loading and takes me to recovery screen tried recovery but still takes me there again and again, tried to boot...
Please take a close look at the disk you are using to install "Windows 7 Ultimate". It is definitely a "Recovery Disk" for Windows 7 Ultimate. You cannot install Windows 7 with a recovery disk. Recovery disk always is used to repair corrupt or damaged files of Windows OS and requires that the Operating System is already installed. You need a "Windows 7 Ultimate" Installation disk to install Windows not a recovery disk for Windows.
1helpful
Hy i install window 7 in imac desktop after installing black screen apper keyboard blinking 3or 4 minits not working even when cd is booting when it say"press any key to boot cd' wirless keyboard is...
Hi, by reading your question I am not sure if you are saying that when you load up Windows 7, nothing shows but a black screen or if your keyboard is not working. Well anyway I am going to try and help with both.
If you are getting a black screen when loading up, this is probably because your computer does not support Windows 7. In order to use Bootcamp and install Windows 7 you must be on Mac 10.6 and up or Snow Leopard. That is the only OS that supports Windows 7 and if you do have Mac 10.6 but you still have the black screen it is probably because the actual computer can't handle it or the drivers in the computer might not support it. I would say anything before 2005 will not be able to load Windows 7, but I am just taking a guess. For my second solution dealing with your wireless keyboard, when you installed Windows 7, no drivers were installed because Windows does not support them yet. This is why your keyboard was blinking, it was looking for a connection because it was not connected to anything. When installing Windows 7 you will need a wired mouse and keyboard because your Apple Wireless Bluetooth Keyboard is not yet pared with the computer. In order to install the drivers to make your keyboard work you need to load up Windows 7 by holding down the "option" key when turning on the iMac. Then once you select Windows 7, and it loads up to the desktop you need to insert your Mac reinstall CDs, then follow the on screen steps to install the drivers. From there you should be able to go into the control panel and add a wireless keyboard under the devices panel.
I hope this helps, Justin
2answers
Hwo to instal windows 7
Welcome to FixYa.
Please elaborate your problem providing us with more details.
Thanks for using FixYa.
I buy this notebook 5 year before and that time window xp was installed but now i install win 7 and problem is that my sound card is not working now, pls tell me from where i can install the suitable sound...
Hi, the problem is that your system wasn't designed for Windows 7. You could try the Packard Bell website and down load the latest driver, even its not for Windows 7. Or try the Realtrek AC'97 sound driver, its free to down load from a google search. Your other potenial problem is that you will need minimum of 2Gig of memory to run Windows 7.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
