20 Most Recent Polaroid FLM-3732 Television Questions & Answers
0answers
0answers
Polaroid tv
Be the first to answer 9/15/2017 12:21:03 AM • Polaroid... • Posted on Sep 15, 2017Be the first to answer
0answers
Please help my Polaroid 37" lcd
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3/8/2017 11:51:51 AM • Polaroid... • Answered on Mar 08, 2017
Polaroid 373b Blues!
what does the board look like in same area as black arc spot on case (damaged??) the high pitch whine you hear is the high freq switching going on in the electronics , this by itself is not too bad ( I had an old floursent clock that whined so loud it made my dog howl !! and it still works !! ) but when it accompanies a non functional device id say the power supply is straining to provide power (over loaded)
3/4/2017 2:02:58 AM • Polaroid... • Answered on Mar 04, 2017
Cable connection broke off while unscrewing cable wire
The unit may be repairable depending the damage done to the input circuit that the connector was connected to. The board can probably be replaced if not repaired. You can call Polaroids customer support at this telephone number. 1-866-289-5168. Give them the model number of your television and the problem you had with the cable connector coming off inside the television.They should be able to tell you how your can get the unit repaired. I hope this information helps you with your problem.
4/23/2016 9:14:56 PM • Polaroid... • Answered on Apr 23, 2016
Why does it make a siren like noise when i turn on?
You have a bad capacitor in the power supply. Take it in for service or replace yourself. Remove case and fire it up. You'll know right where it is.
1/3/2015 7:40:52 AM • Polaroid... • Answered on Jan 03, 2015
Manual for a Polaroid p50 led14
Go to this site to download your manual. http://www.manualsonline.com/
1/3/2015 7:27:25 AM • Polaroid... • Answered on Jan 03, 2015
How make small pic bigger
Press the zoom button on the remote control. http://electronicshelponline.blogspot.com/
7/3/2014 5:34:50 AM • Polaroid... • Answered on Jul 03, 2014
I have a vizio and the cable end broke off in the back can i get cable by running rca jack in the back oftv
Dewayne, some cable/Satellite boxes have the option to use RCA outputs to get cable. If your box has this you are fine
6/9/2014 11:17:08 PM • Polaroid... • Answered on Jun 09, 2014
Cable cord broke off back of vizio tv other ways to get cable
Replace the cord or watch TV at a relative's house. Seriously, If you cannot replace the cable, your cable company will repair it for you. Probable for free - especially if you say you need to cancel your subscription unless they do it at no charge.
5/20/2014 1:31:24 AM • Polaroid... • Answered on May 20, 2014
0answers
No sound
Be the first to answer 3/29/2014 3:33:21 AM • Polaroid... • Posted on Mar 29, 2014Be the first to answer
0answers
Led flatscreen TV
Be the first to answer 2/27/2014 6:25:50 AM • Polaroid... • Posted on Feb 27, 2014Be the first to answer
Oversaturated Greens, Noise from Speakers, unresponsive buttons
This is meant to be under televisions, not PC notebooks.
2/11/2014 4:35:00 PM • Polaroid... • Answered on Feb 11, 2014
No power for 3700
Replace capacitors in power supply area.
2/2/2014 10:35:19 PM • Polaroid... • Answered on Feb 02, 2014
Televison & Video Logo
252 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
2 blown casps in polaroid tv fix
  • Televison & Video
