2002 Dodge Intrepid Logo
K
Kenneth WILLIAMS Posted on Apr 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine light flashes 9 times and my car want start?
I have been trying to figure out why the engine light flashes 9 times
Alex Daddi Gardiner
Level 2:
Sergeant:
  • Expert 355 Answers
  • Posted on Jul 12, 2014
Alex Daddi Gardiner
Expert
Level 2:
Sergeant:
Answers
355
Questions
Helped
107468
Points
774
Have some one put a obd code reader on that i cant think of what would cause it to flash 9times and dont start
4 Related Answers
Anonymous
  • Posted on Aug 11, 2008
SOURCE: Car losing power and turning off
if your car is 2003+ try turning the key to run (but not crank) then to acc. 3 times and the engine codes will show up on the odometer, then you can look up what those codes are to help diagnose some of the problems.
Jonah Oneal
  • 14092 Answers
  • Posted on May 07, 2009
SOURCE: Dodge Intrepid 2002 check engine light and car will not start
scan it .sound like egr valve and oxygen sensors.
Anonymous
  • 373 Answers
  • Posted on May 27, 2010
SOURCE: check engine light blinking 10 times
The pcm (powertrain control module ) is telling you it has a set code in the memory. Take the car to a parts place like (auto zone ) and have them to run a scam on the pcm for a trouble code. Once you have done that then you will be able to correct the problem. Hope this will help you.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 19, 2012
SOURCE: CHECK ENGINE LIGHT FLASHES 10 TIMES
Run scanner and computer for test can be MIL see the diagram
My car tried to shut off going down the highway. Then it was shaking mildly. engine light came on flashing.This is a 1999 Dodge Stratus- 4cyl.-2.7 engine
The flashing engine light means the miss is bad enough to cause damage to the catalytic converter. The check engine light does not involve engine oil.
Are you saying the timing belt is not turning the cam ?
2answers
Check engine light flashes 9 times and car want start?
You need to get the OBD2 scan on the car to give you the codes. See if you can barrow one if not you will need to buy one. it will give you all the trouble codes for the car.
2001 saab 9-3 check engine light flashes 5 times
a flashing check light usually means a problem needs to be attended to right away most auto store such as advanced auto/auto zone etc offer free scanning to trouble code will give u a start location so u can make repairs if necessary
Engine shutting off after 1-hour driving time
You'll have to figureout if it is a fuel or ignition problem.What are the trouble codes ?
3helpful
2answers
I have saab 93 2004. Has 74K miles. Check engine light on. help
TAKE CAR TO ANY AUTO ZONE THEY WILL SCAN IT FREE TO SEE WHAT SENSOR IS BAD.
1helpful
2answers
1995 saab 900 turbo
Two most common problems for this are the DIC and the fuel pump. Can also be the CPS. First check the code. You can try this first before going to a code reader: 1.With the car already off, switch on the ignition without starting the engine. 2. After approx. 6 seconds, the 'Check Engine' light goes out for an instant before lighting up again for 3 seconds. This 3 second flash is a warning that the actual flashing code is about to start. 3. The flashing code consists of a number of short flashes lasting 0.4 seconds. The 'Check Engine' light goes out for 2 seconds between each new flashing code (if there is more than one fault). 4. After the last flashing code, the 'Check Engine' light goes out for 3 seconds before lighting up again for 3 seconds, after which the flashing codes are repeated. Readout continues in this way as many times as you wish. Number of flashes / Function 2 / Manifold absolute pressure sensor 3 / Temperature sensor, manifold 4 / Temperature sensor, coolant 5 / Throttle position sensor 6 / Oxygen sensor 7 / Adaptation 8 / Purge valve (EVAP valve) 9 / ECM, internal fault If no flashing codes display, the problem is something else (other than those nine listed above) and must be determined using a generic code reader that supports OBD 1, or using the GM/Saab Tech II code reader and programmer. My money is on the DIC as it is a very common failure component and fuel pump failures rarely throw a code. The DICs are good generally to 100,000 to 150,000 miles, but this varies wildly, especially if the car is run with overgapped plugs for any length of time. The plug gap should be 1 mm and no more. Cars that are scrupulously maintained vis-a-vis the plug gapping can see DICs last over 200,000 miles.
1helpful
2answers
Engine light is still on after we have replaced numerous parts
The engine light is on, Have u checked for fault codes? To check codes, pull back carpet on passenger side of car to expose ECU (electronic control unit) at 'foot' location on that side. There is a small LED display at the top of the unit, turn the key on (not running) and check for flashes, u must count the flashes to determine what codes are stored in the computer. Short flashes are for codes 1-9, two digit codes use long flashes for the 1st #, followed by short for the 2nd. There is a pause between codes, so there may be more than one. Check and let me know what u find.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
