I follow instructions but it seems not working pls help. my television is 32 inches sanyo LED tv.
SOURCE: standart television
How to change TV setting to video mode so I can connect a VCR/DVD combo player.
SOURCE: How to play PS2 on Sanyo tv set
you can play your PS2 via the RF in (ANT IN ) at the back of your TV .
For this you will first have to connect a AUX to RF converter jack device to ANT IN jack of TV.
Then determine the OUTPUT CHANNEL of the PS2.
(Channels-1 to 12 is in VHF band
channels-21 to 69 -UHF band)
Put the PS2 "ON"
TUNE the TV set to the frequency of PS2.
SOURCE: I have a Sanyo 32 inch tv, model # DS31650, that has no sound
My book says no audio, storm damage need to replace ic 3601 (CXA1279AS part number 409 279 3109) this is probley a surface mount ic on the bottom of board.
SOURCE: I have a 32 inch Haier TV and my comcast cable
I dont know where you work why dont you ask the gentleman if he has a remote with a red or gray center. Then properly tell him the auto search sequense. Hit tv button hold set up it will flash twice. Hit these numbers 9-9-1-1 then channel up until set turns off with remote with red ok/select button. Haier tvs are programmable the only ones to watch are Olivia, new RCA and a view others hope this helps anyone. If you have a comcast remote with gray center use it as a tire chuck and have comcast send out a new one.
