Nikon COOLPIX L18 Digital Camera Logo
A
Anonymous Posted on Apr 12, 2014
Prongs inside mini usb port on camera nikon d40 bent
Brett Bosse
Level 2:
New Friend:
  • Expert 116 Answers
  • Posted on Nov 27, 2014
Brett Bosse
Expert
Level 2:
New Friend:
Answers
116
Questions
14
Helped
23454
Points
229
Best thing to do is send it in for repairs but if your confident in opening it up then just make sure you take note of exactly how you opened up so you are able to put it back together again and then carefully bend the pins straight or how ever they were originally remember if over bent you run the risk of snapping the pins and then you will have to (and this is not often very easy to do)source the unit and then have the skills of soldering and this is also not very easy
5 Related Answers
Anonymous
  • 480 Answers
  • Posted on May 22, 2008
SOURCE: Nikon D40
Hey climiocid,
If what you mean is your images don't display on the LCD screen after you take the picture your image review option has most likely been turned off. If your camera just never displays any images I would try doing a hard reset on the camera by shutting off the camera and opening the connecter cover and pressing the reset button which should reset the camera to factory specifications. When resetting the camera this way remember this resets the cameras' clock. If none of this works I would have the camera looked at by an authorized service technician. You can find an authorized service center by contacting the manufacturer, or you can always bring your camera to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Anonymous
  • Posted on Jun 01, 2008
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
patmartini
  • 6 Answers
  • Posted on Jun 06, 2008
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
A
Anonymous
  • Posted on Jun 20, 2008
SOURCE: d40 software
No drivers needed for Vista either. But make sure that you use the USB cable included with the Nikon D40x. My Cannon cable (although it looks identical, produces a Device not recognized error) with the D40x. The Nikon cable works fine, of course... I now have them marked.
Jeff Marcus
  • 115 Answers
  • Posted on Apr 27, 2009
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
I can't dump pictures onto my computer through a
It might have just happend due to recent update of your system
so the solution would also be another update
but before that go to the device manager , locate other devices and right click on it and click on update drivers, restart the system, if that works its fine else go on to the following link and download the latest version of the Nikon Software
http://support.nikonusa.com/app/answers/detail/a_id/61/kw/61/r_id/116678#Anchor-8
Connecting to pc message
connect the mini usb calbe to Camera only. Camera will working like without cable. Go to setup menu and Change USB setting to P, PTP. the unplug the miniusb and hopefully camera will work as it one.
It worked for me :)
Attila
2helpful
Computer cant find USB drivers for Nikon d40
I had the same problem with my D40x - I changed my USB cable to a much more robust one and all my problems went away.
You shouldn't need a driver, most OS's will recognise it as an imaging device.
2answers
Nikon D40 stopped working
try using a different usb port. might be the pc just can't detect your cam.
3answers
Nikon D40 Download Problems
It could be the card reader is unable to read the card not your pc. You might be able to get a firmware update from card readers web site.
Damaged USB port
THIS PORT IS SOLDERED INTO BOARD.. YOU MIGHT BE ABLE TO BEND IT BACK VERY CAREFULL=Y. BUT MOST LIKELY IT WILL JUST BREAK OFF. THE PINS ARE VERY FRAGILE.U MIGHT WANT TO CHECK WITH WWW.PARTSTORE.COM FOR PARTS BUT THIS WILL BE HARD TO FIX
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
