20 Most Recent Nikon D40 Digital Camera with 18-135mm lens Questions & Answers
What do you mean by "opened it up"? I hope you did not disassemble your lens. If you did; STOP NOW! Without training, you will never be able to reassemble your lens yourself. Contact your closest Nikon USA repair depot or a local qualified camera repair man.
If, on the other hand, you mean that you simply removed the lens from your camera and the part in question is on the rear of the lens, please post a photo of the lens with an arrow or some type of identification of the part you are talking about.
One other thing; have you asked your photography instructor to look at your lens?
Nikon D40... | Answered on Jun 08, 2014
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Nikon D40... | Answered on Aug 12, 2012
Remove the lens cap...
Nikon D40... | Answered on Nov 25, 2010
Press the info button on the back to bring up the shooting information screen. The second item from the top on the right column is the image size. Press the button to activate the settings, then use the multiselector to navigate to the desired setting. Press OK, use the multiselector to select the desired size, then OK to set it.
Your choices are Large (3008x2000), Medium (2256x1496), and Small (1504x1000).
Note that you cannot change the image size if you're shooting RAW. The image quality setting is the one just above the image size.
Nikon D40... | Answered on Oct 11, 2010
Use a card reader instead of the camera.
Nikon D40... | Answered on Aug 12, 2010
You can download a manual in PDF format from the manufacturer's web site at http://support.nikontech.com/app/answers/detail/a_id/13948
You can order a printed manual from http://www.nikonmall.com/category/instructionmanuals
Nikon D40... | Answered on Jun 28, 2010
Yes , it is a power saver. I remember there being a way to change it in the menus. Note: the "monitor" stays on for different times depending on mode. There is a manual on line. I had better luck just playing with the menus. The menu your looking for is easily over looked.
Nikon D40... | Answered on Jun 28, 2009
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Nikon D40... | Answered on May 09, 2009
Is the camera in airplane or power saving mode?
Nikon D Cameras | Answered on Feb 02, 2019
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
Nikon D Cameras | Answered on Aug 02, 2018
switch button got damage due to hard press so you need to replace it
Nikon D Cameras | Answered on Aug 24, 2017
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Nikon D Cameras | Answered on Dec 11, 2016
Have you tried to see if you camera is running the latest firmware? If its not update it.
Nikon D Cameras | Answered on Jul 02, 2016
Nikon D40 Digital Camera with 18-135mm lens Logo
11 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
