Washing Machines Logo
A
Anonymous Posted on Jul 13, 2017
OE error My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked to get my clothes out. Cleaned out the filter and then decided to try again running the rinse and spin cycle. It did spin and filled with water but a couple minutes into the cycle I got the OE message again. Any thoughts
Marvin
Level 3:
Top Expert:
  • LG Master 85,242 Answers
  • Posted on Jul 13, 2017
Marvin
LG Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061159
Points
266281
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Feb 25, 2008
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
johnychel
isaac johny
  • 796 Answers
  • Posted on Mar 23, 2008
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Anonymous
  • 51 Answers
  • Posted on Jun 12, 2009
SOURCE: Machine won't spin and rinse and stops with an "OE" message.
it could be as simple as a wire has come off the pump during transport or the pump was about to die.
check if wires have come off pump and if ok then with a little water in the machine see if you can blow some air back down the drain hose to see if there is a blockage in the hose or the pump if there is you will have to remove the hoses from the pump and clear the obstructions
steelskyway
  • 22 Answers
  • Posted on Jul 31, 2009
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
Paul
  • 381 Answers
  • Posted on Dec 15, 2009
SOURCE: LG Tromm Washer flashing OE. drained from the
Take the front off and check all the hoses going in and out of the drain pump.
What is an "OE" error message on an LG Tromm clothes washer?
OE means Water may not drain properly
This causes:
Your pump is clogged.
Your pump is not connected.
Make sure your pump is repaired, and try again.
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
6helpful
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
4helpful
2answers
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
3helpful
I have the LG Tromm 27'' Front Loader model WM2277HW
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
3helpful
Getting the OE error message on LG Tromm
4helpful
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
1helpful
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
3answers
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
