Televison & Video Logo
A
Anonymous Posted on Apr 10, 2014
I have a symphonic TV and I am trying to connect my ps2 into it, nothing is working. I don't have the original remote control for the TV either. I have tried connecting the red, white, and yellow cords from the ps2 to the correct spits on the front and back if my TV and nothing has worked. What do I do?
5 Related Answers
Jaime Hernandez
  • 2351 Answers
  • Posted on Jan 16, 2008
SOURCE: PS2 hook-up
I would suggest to feed video from another source such as DVD or VCR to the same input, if the video is visible from other sources on your TV; that means the video cable from your PS2 is defective. If you did not see any video from the DVD or VCR nor the PS2, it means that there maybe a loose connection inside the TV on the video input.
Hope this helps.
Anonymous
  • 99 Answers
  • Posted on Mar 21, 2008
SOURCE: TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Anonymous
  • 15 Answers
  • Posted on May 26, 2008
SOURCE: Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
Anonymous
  • 218 Answers
  • Posted on Jul 19, 2008
SOURCE: Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Anonymous
  • 128 Answers
  • Posted on Apr 05, 2010
SOURCE: connecting a PS2 to a zenith tv
you need to buy an a/v to coax adapter.Here is a link for the adapter.
http://salestores.com/rcacrf90.html
hope this helps.
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Lost original remote t the symphonic tv which has
You can get the original remote for a decent price. It is an original replacment remote. You can find it at any of these places.
www.replacementremotes.com
remotes.com
www.mr-remote.com
www.neworiginalremotes.com
You will need the original remote to access the features you want to use.
Trying to get the remote to work on my symphonic
Change batteries?Take it aparts,clean it with Q Tips
with some rubbing alcahols in the rubbers knobs and
clean the films between the circuits board.Don't work after this.Buy a new remote at this website.1-800-remotes Factory Original.Yes,universal remotes it cheaper,but causes univeral codes,more headaches later.
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
I cannot get it to work for my T.V.
first try the Funai, Sylvania, and symphonic codes. if none of them work try the code search option. if you need the manual and codes for this remote. go here: http://www.replacementremotes.com/store/productdetailp.cfm?productid=61355. if still unprogrammable then throw the remote away because it just isn't going to work. Buy the original equipment remote at www.replacementremotes.com.
1helpful
3answers
Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
1helpful
2answers
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
