20 Most Recent Symphonic WF104 Questions & Answers
1150 worked for me :o)
Symphonic WF104 | Answered on Oct 22, 2016
10180, 10171 those are the symphonic remote codes for comcast.
Symphonic WF104 | Answered on Aug 09, 2015
It looks like there are a range of values that have been quoted online. It would appear to depend on the make of the universal remote. I have found 456 or 458 stated.
If you are using a comcast remote I have seen 0675, 10180 or 10171.
Symphonic WF104 | Answered on Oct 25, 2012
Firstly, we need to determine if the remote is working correctly:
1) remove batteries from remote
2) press each button on the remote twice (do this one button at a time). This will discharge any residual current stored in the remote's capacitors.
3) insert fresh batteries (ensure these batteries provide good charge)
If this does not reset your remote (or still does not work), then suspect your remote is faulty.
Please let me know the outcome of the above test.
Cheers,
Symphonic WF104 | Answered on Aug 01, 2011
I'm guessing you have tried these already, but, you can try:
2017, 2213, 1029, 1134, 1150
if it is the ER1
014, 186
If that doesn't work, try a search by doing this:
Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
AUX) until the mode keys blink twice. For example, to search for a TV code, press
and hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press PLAY . The remote automatically tests each code in its library, beginning with the most common codes. The mode key blinks once each time the remote transmits a new code. The mode key
blinks twice when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press channel up or channel down to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
Symphonic WF104 | Answered on Oct 30, 2010
Unfortunately not all dvd players can be unlocked like that. You can try to rip the dvd to your computer and then burn it region free. Just make sure not to violate any copyright laws as that is why the region protection is there in the first place.
Thank you,
Lee
Symphonic WF104 | Answered on Aug 17, 2010
With a DVD you DO NOT select a Channel. Instead you select the AV, Audio Visual input.
Symphonic WF104 | Answered on Feb 09, 2010
10463 try using this code
Symphonic WF104 | Answered on Jul 21, 2009
Symphonic WF104 Logo
45 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
need time warner remote code dynex lcd
  • Televison & Video
