Left side surface burners not working
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
SOURCE: My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
SOURCE: surface burner light stays on when all burners are
if this is the light indicating aburner is still on one of your switches is shorted
