SOURCE: Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
SOURCE: hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
SOURCE: My Hotpoint WF860 will spin on rinse/spin load but not on a wash
no its the programer at fult
SOURCE: where is the filter on a hoitpoint ultima wf860
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The filter
is under the rear of the machine inside the sump hose. Remove the lower rear
inspection panel and tilt the machine forward, keep it tilted by placing a tin
of peas or something under it at the rear. Now put a shallow bowl or dish under
the sump to catch any water that may still be it the drum and remove the
retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing
any repair) For more tips on repairs use this link selfix-uk
