Xerox 7132
SOURCE: fault code 010-333 xerox 7132
Most likely you will have to have the fuser replaced. That is an overheat problem. You may just have a piece of paper wrapped in the fuser shutting it down. You can open the left hand drawyer adn remove the fuser , check inside it and put it back in and see if that clears.
But, more than likely you will have to put in a new fuser.
SOURCE: xerox 7132 noise when picking up paper from bypass
On this model, sounds like the clutches are bound up in the bypass feeder.
These gears are in constant motion with other gears in rotation in the copier.
The mechanical gears on the bypass feeder need to be disabled. The machine cannot be used. The work is involved in order to do this repair job.
If all else fails, Place a service call to Xerox for repairs before other gears get broken, then major problems can occur.
SOURCE: xerox work center 7132 will not boot up. error
Try to unplug the device directly from the socket wall and leave it for 5min. Plug in again. If message still occour it could be related to 2 reasons.
1. Sensor problem leading to "ghost" message -- require eng.
2. Toner replacement also causes this message.
Even if you do couple of boot routines you might want to have someone onsite to have a look at it. It might require parts.
SOURCE: The Windows 7 mini drivers for the Xerox 7132 only
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
SOURCE: 089-311 error code for xerox copier #7132
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor
