Ricoh Aficio SP C320DN Color Laser Printer Logo
A
Anonymous Posted on Mar 27, 2014
Locate the serial number
Where is the serial number?
I have an on old Cobra 86 KLR with a microphone
I can certainly help you try to locate the serial number on your Cobra 86 XLR microphone. The serial number is usually located on the bottom or side of the microphone body, or it may be stamped into the metal body of the microphone. It is also possible that the serial number is located on the bottom or side of the microphone base or on the microphone's packaging or documentation. If you are unable to locate the serial number on the microphone itself, you may want to try looking for the serial number on the documentation or packaging that came with the microphone, or on the manufacturer's website. If you are still unable to locate the serial number, you may want to contact the manufacturer for further assistance.
Jan 04, 2023 • The Music
Where is the serial number located
Digital Imaging: How to find the serial number? : FAQ : Sony ...
https://sony-paa-pa-en-web--paa.custhelp.com/.../digital-imaging%3A-ho...
Jul 9, 2015 - If you have a Camcorder, Digital Still Camera or DSLR Camera, Theserial number can be found on the label located at the bottom of the ...
How to find your camera's serial number - Kodak
www.kodak.com/eknec/PageQuerier.jhtml?pq-path=5231
KodakThe serial number for KODAK Digital Cameras is located on the bottom of the camera, and is made up of both letters and numbers. There should be three to five ...
[PDF]A guide to locating Canon equipment serial numbers
Dec 08, 2015 • Cameras
Getting pride information for a serial number
Pride Mobility Products location serial number ... - Fixya
www.fixya.com > ... > Tags > location serial number > Mobility Scooters
Pride Mobility Products mobility scooters location serial number related questions and answers. Ask your Pride Mobility Products questions. Get free help from ...You visited this page on 7/20/15.
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
1helpful
2answers
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
Can't print need model number
Here is the Canon WEBSITE for the PIXMA. Your can find manuals, drivers, specifications, etc. here.
This is where the serial number is located, look here.
Locate the Serial Number The serial number of the PIXMA MP750 / MP780 is located at the back of the printer towards the bottom edge, as shown below.
  • The serial number for the MP750 starts with three letters (AGA) and ends with six numbers. Example: AGA012345
  • The serial number for the MP780 starts with three letters (AHB) and ends with six numbers. Example: AHB012345
good luck
1helpful
2answers
Have been directed to find my Serial number for my Gateway deskto
Hi
Thanks for using FixYa. The serial number is usually located on the top, left, right, or back panel of the computer. The serial number is printer on a black sticker with white lettering.
Also see this link for Serial code location--
Gateway Computer Serial Code Location
Also see this link for more info--
Gateway Computer serial location
And if you are unable to locate the serial code anywhere then right click on My computer icon on desktop, then click on properties and from there you will be able to see the serial number from there.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
12helpful
2answers
Serial Number location on LG WM2016CW
just open the door on your lg and the serial number is on a tag.
About serial key
Details Issue: Where is the serial number located?
Solution: Locate the serial number MP150
topFrame=findTop(this); Locate the Serial Number The serial number of the PIXMA MP150 is located inside the printer, as shown below.
  1. With the printer powered on, lift the scanning unit and pull the scanning unit support down into place.
  2. The serial number is attached to the back wall inside the printer.
    It starts with four letters (JCBA, JCBB, JCBC or JCBD) and ends with five numbers. Example: JCBA01234, etc.
.footergray { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: none; font-weight: bolder; } .footerblack { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: underline; font-weight: bolder; } © 2008 Canon U.S.A., Inc. All rights reserved. Duplication in whole or in part without permission is prohibited.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
