Watches Logo
A
Anonymous Posted on Mar 17, 2014
Damaged ceramic and caseing and ******** model ar.1410111205
1helpful
Repair of ceramic band of Vicence white ceramic band, can it be repaired?
Question edited for clarity, 'Vincense' to 'Vicense'.
Amazon do replacement white ceramic bands.
https://www.google.com/search?q=Vicence+white+ceramic+band
They appear to be a watch without a maker and are sold on QVC, eBay and Etsy so not of Italian manufacture as the name suggests. Very fine Chinese watch.
https://www.google.com/search?q=Vicence+watch
You could just paint the chip with a matching colour of nail polish.
Jul 12, 2023 • Watches
1helpful
What size battery does my Emporio Armani AR-5331 take
The size of the battery that your Emporio Armani AR-5331 watch takes will depend on the specific model of the watch. Some common sizes for watch batteries include:
  • CR2032: A small, coin-shaped battery that is commonly used in small electronic devices such as watches and calculators.
  • CR2025: A slightly smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
  • CR2016: An even smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
It is best to refer to the user manual or contact the manufacturer to determine the correct size battery for your Emporio Armani AR-5331 watch. Using the wrong size battery can damage the watch or cause it to function improperly.
Can this be repaired? It's a ceramic Versace
no probably not it needs a new case! i would try to return to manufacturer
How about some standard Nd:YVO4 crystal series?
Antyco have a lot of standard series kits of diode pumped laser optics, is's easy to select what you need listed below
Part Size
(mm) Nd Coatings S1 S2 NYV001 3x3x1 0.5% AR@1064nm, HT@808nm AR@1064nm, NYV002 3x3x1 1% AR@1064nm, HT@808nm AR@1064nm, NYV003 3x3x1 1% HR@1064nm, HT@808nm, AR@1064nm, NYV004 3x3x1 1% HR@1064nm,HT@808nm,HR@532nm AR@1064nm, NYV005 3x3x3 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV006 3x3x3 0.5% HR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV007 3x3x5 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV008 3x3x8 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV009 3x3x12 0.5% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV010 3x3x3 1.0% AR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV011 3x3x3 1.0% HR@1064nm, HT@808nm AR@1064nm, HT@808nm NYV101 3x3x0.5 3.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV102 3x3x1 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV103 3x3x1 2.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV104 3x3x3 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV105 3x3x5 0.5% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV106 3x3x2 1.0% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm NYV107 3x3x2 0.5% HR@1064nm, HR@532nm,HT@808nm AR@1064nm&532 nm
For more: http://antyco.com/
1helpful
RADO DIA STAR HIGH-TECH CERAMICS Case back is broken, how to get case back? original case back is very expensive so can I get the fake one?
Thank you for the answer but my question is if I can get fake case back and how? cos original case back is nearly same price as watch
Jan 22, 2013 • Watches
I have a le chateau ceramic sapphire watch and want to remove a link
mcdevito75 here, You"ll need a link remover tool, available on ebay, but my advise is if you know nothing about watches, visit a small watch repair shop in your area and have them remove the link, also, hold onto that link in case you need it replaced later.
Aug 17, 2010 • Watches
I took my timex wr30 into have the battery replaced and back was damaged I need to know where I can order a new one
only from timex they need model and serial number of case back or and shop that sells timex will be able to order case back or any good repairer.
Cant get the white band clean
I love watches. My collection: Breitling Colt, Bulova Accutron, and a few others.
Yours is no slouch either. I believe it's around $2500. and the band is special, very special. It is made from ceramic and can not be replaced with any other band except for the one it came with. That being the case, if you are going to pay that much for your watch you should expect some quality service from the maker in regards to things like this. So before you do anything else give them a call and ask them if they have any recommendations about cleaning it.
If you get a response some thing like "No problem just send us a blank check and the watch and we will fix it right up, Honest" tell them to get ben........never mind. Just hang up. Their # 1-888-455-9200
If you are going to try and clean it you need to understand just how hard ceramic is. I have ceramic tool cutters almost as hard as diamond cutters so it will take some patients.
The first thing I would try is to let the band soak in bleach. You might be surprised at how well that works. Let it soak awhile. The longer the better
The best thing is to find a polish made specifically for ceramic.
I would try a auto paint supply store. They should have good quality polish for ceramic clear coats. It may also be a good idea to get a piece of white ceramic cutting plate/board and test a spot. I would also use a small Dremel polishing wheel. Dremel also makes a soft polishing stone that you mith want to try depending on how bad the stains are.
Remember a ceramic cutter board is a cheap way to test before you try anything on the band.
I really hope something here helps.
Let me know if you need any other help and please let me know of any success or failure and I'll try and give additional assistance.
Top Giorgio Armani Watches Experts
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
