I am using a DLINK DSL-2730U router to block some websites on my LAN. But still, a particular machine running Mac OS X is able to access the blocked websites while others can't. What's going wrong with that machine?
SOURCE: dlink dl524
I use Network Magic to do this ... yo ucan also restrict access by MAC asddress.
Google it to find it (a Cisco produt) read the deal and enjoy it.
I hope this helps you
Thanks for using FixYa.com
a
SOURCE: setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
SOURCE: HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
SOURCE: I am not able to access my work L2TP VPN from home
disable the firewall and antivirus in your system and check it
Thank you
