As Melanie says, Kitchen Aid can help you with the age of your machine if you supply them with model number and serial number. They can also point you to where you can get the knob. It is part of the lever that it goes onto so you will need to specify lift lever or speed control lever. Contact your local Kitchen Aid agency, find them online or in the phone book.As Melanie says, Kitchen Aid can help you with the age of your machine if you supply them with model number and serial number. They can also point you to where you can get the knob. It is part of the lever that it goes onto so you will need to specify lift lever or speed control lever. Contact your local Kitchen Aid agency, find them online or in the phone book.
Hello Denise, First things first your K90 is a referbed model. The number od R's in front of the model number (which starts with the letter K ) is the number of times that the machine has been returned to the factory for over hall. next your machine was built / manufactured in Greeneville Ohio in 2002 sometime in April. Now what part do you need ?? Knob or lever would mean many things on a K90 Ultra Power, can you be more specific??Hello Denise, First things first your K90 is a referbed model. The number od R's in front of the model number (which starts with the letter K ) is the number of times that the machine has been returned to the factory for over hall. next your machine was built / manufactured in Greeneville Ohio in 2002 sometime in April. Now what part do you need ?? Knob or lever would mean many things on a K90 Ultra Power, can you be more specific??
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
It is correct that the knob is not separate from the shaft it is attached to. If they are obsolete then hop into your local Kitchen Aid retailer and see if your missing knob looks same or similar to a current model, if so order for a current model, lever the knob off the shaft (carefully) and tap it onto your bare lever. I use a soft faced hammer for this. These folks here should be able to help if you are USA based. http://www.searspartsdirect.com/
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
denice,
im sorry to hear what is happening with your mixer. I do not know any places around that area. but i would recommend service. It sounds to me as if it could possibly be the motor assembly not lubricated properly or it could be a power switch going out. either way will be serious to the operation of your mixer. i am not to familiar with that model but im sure the parts can be redily available
Correction it was built in june
