* Check bunn.com for a free download of manual for this brewer.
* If this is a pour over (VPR, VPS, etc.) then you must pre fill it then pour in one pot of water to get one pot of brewing hot water out of it.
* If this has an external tank of water then it must be filled and make sure the float sensor works and pops up to indicate a filled tank.
* But most likely this is a CWTF, CW, or larger commercial brewer that has a plumbed in water line. If this is the case then the tank must be pre-filled and heater turned on. (a switch in the back) Installation is usually done by the vendor or service tech. It should have been tested and brewed to check water level of brew. Follow the brewing instructions.
* Still not working? Call vendor for service. It could be timer, brew switch, water level board, water fill valve,brew valve. all need check and service to replace as needed. Many larger units have high voltages so call the tech to be safe.
Aloha, ukboy57
