I set the camera to record time and date ,it does this ok but wont attach the time and date to the photo itself ..when i view the photo it is just a plane photo with no info on it. why is this?
There will be a setting where you tell it to add the time and date by choosing ON. This is different to where you set the time and date. Generally it is within your menu and may be with ""setup menu"" and called "date stamp". If you set this to "on" it should do the trick.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Firstly, set time and date in the camera: 1. Display MENU. 2. Click on each of the tabs until youfind a dropdown with Date/Time on it. 3. Click on this and follow the prompts. 4. On completion press OK. The date and time will be effective from the time you press OK. I am not aware of any Canon camera that does enable the entering of time/date on all images. However, it is recorded in the EXIF data that all digital cameras record with every image. You can use ZoomBrowser - a software program that comes on the CD with Canon Cameras - to write the date/time on selected images. The date and time written will be the actual date and time the image was recorded on your camera i.e. the date and time you took the photo. With the image open you should be able to find the time/date option.
Hello and welcome to FixYa! This following steps allows you to set the system time which will be displayed on the photos.
Press the Up or Down buttons to select the Date option in the Setup menu.
Press the OK MENU button.
Press the Up or Down buttons to select a Date option from the menu that appears
On selecting "On" the date will appear on the photo once it is taken. On selecting "Off" no date will appear on the photo. On selecting "Set Date" the Set Date settings screen will appear. You will be able to change the date settings that will appear on the photo once it is taken. To Set the date:
Press the Up or Down button to enter the Set Date option.
Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, Second and Date Format type.
Press the Up or Down button to set the Date and Time digits.
Select the first option of the Date format and press the Up or Down button to set the date format that appears on the top line: YY MM DD; DD MM YY; MM DD YY.
Press the OK MENU button to confirm, save the changes and exit.
You have done it. I hope this solution helps you If you have any more query or issue regarding your problem do inform me.
Thank you for using FixYa!
Hello, according to the manual for your product https://wikis.utexas.edu/download/attachments/15045757/Sanyo_VPC-CG20_manual.pdf you should setup the correct date and time as shown on page 20. The date and time is recorded into the picture file, but it is not shown onto the picture itself (like in old analog film cameras). You can view the date and time of a particular photo on a computer by right clicking the file icon and choosing 'properties' and then the 'details' tab (I'm assuming you have a microsoft windows operating system). If you want the date to be onto the actual image itself (for printing purposes, I suppose) you have to type it yourself with an image editor. Let me know if you need further assistance, I hope this helped you, Bye
I'm pretty sure this camera wont do this. However it does record the time and date (as well as a whole bunch of other information) as 'exif' information. This can be viewed in Digital Photo Professional (on the disk that came with the camera) and in other photo editors.
