Vehicle Parts & Accessories Logo
A
Anonymous Posted on Mar 11, 2014
Hesitation while driving - Vehicle Parts & Accessories
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 09, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141129
Points
7635
Check to make sure you have enough fuel.
3answers
My 2008 Chrysler Sebring is hesitate about going from park to drive but shifts out good
When you say hesitation do you mean the engine will rev but the transmission won't engage
Why does my 4 wheel drive hesitates to engage when I make turn?
Simple things first. Check your transmission fluid.
My 2010 Jeep Compass hesitates while i am driving, what is the problem
if your engine light is on you can stop at most any auto parts and they will plug into it free and let u know exactly the problem is most hesitations start with simple solutions if u get them soon there r many things which will cause hesitation dirty air filter number 1 cause alto if i was u i would take the guess work out swing into a autozone oreillys napa any 1 of those will plug into it get the code and tell u what is wrong and clear it for u too
2007 Ford Freestar vibration and hesitation with a ****
check the drive shaft "U" joints and slip joint for bad wear . If you have a centre bearing check it for serviceability. pull the plug in the diff and check the magnet for metal bits.
1helpful
When you're driving it hesitates
do a stall test, like start engine let it run then hold the brake pedal with your other foot raise rpm to put load on engine if you feel the hesitate then it could be spark plugs wire or injectors
hope it helps
1helpful
My 91 honda accord drives fine,but after driving for a while it starts to hesitate and only drives when i accelerate and decelerate what's the problem?
If the car starts to hesitate at right around 2000 to 2300 RPMs then the EGR ports on the intake manifold need to be cleaned out. The exhaust gas is flooding only one cylinder and causing the hesitation(misfire of that flooded cylinder) since all the other ports are blocked off with carbon build-up. This happen right when the EGR valve opens, letting in the exhaust gas. To find out if this is indeed your problem, remove and plug up the rubber vacuum hose going into the EGR valve and drive the car. If it stops hesitating, that's the problem.
2answers
Kia sedona 2005 when driving feels like transmission is skipping, hesitating. What is doing on? Just had new transmission put in 7 months ago.
When does it skip and hesitate? While your driving or taking off or turning a corner?
It sounds like an automatic.
1985 fleetwood 4.1L rwd fuel injection the car hesitates severely when I first accelerate and almost seems to back-fire but gets better after warming up, but still not perfect. if I jump into nuetral...
Load issues can be anywhere along the drive train. Put the car into gear with your foot on the brake and BRIEFLY press on the accelerator - if the engine misses/hesitates, the problem is with usually with the engine. If not, it's probably in the transmission, u-joints on the drive shaft or the rear differential. If it's the engine, you will need to do all the usual checks (throttle body, EGR, fuel pressure, etc.).
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
