HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop Logo
A
Arthur Martin Posted on Mar 10, 2014
Can I upgrade a Compaq Presario SR1620NX PC from Windows XP to Windows 7
David Wheeldon
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 11, 2014
David Wheeldon
Contributor
Level 1:
New Friend:
Answers
32
Questions
Helped
4903
Points
74
Christo tech
Level 1:
New Friend:
  • Contributor 57 Answers
  • Posted on Mar 13, 2014
Christo tech
Contributor
Level 1:
New Friend:
Answers
57
Questions
Helped
3357
Points
80
Hi Martin, What all these guys are saying is, No it's not Possible to do a straight upgrade from XP to Win 7,Probably you should back up all your data and do a clean install.
Regards
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 14, 2009
SOURCE: how to completely reinstall windows xp on compaq
For that you will need a bootable CD with Winxp.
Before, be shure you will have an a CD or DVD with drivers for Video and Audio card, network etc, the kits instalation files for programs you use and the serial number for license
Insert your disk with winxp instalation on cdrom or dvd unit and reboot.
When you  will begin to install windows, format the partition.
Anonymous
  • 5 Answers
  • Posted on Sep 30, 2009
SOURCE: Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on May 26, 2010
SOURCE: Compaq Presario SR1620NX Desktop won't turn on
I may state too detailed, and over simplify in my solution.
This is not to insult your intelligence, but an endeavor to explain thoroughly.
To bypass the Power On switch, one uses a jumper wire to jump the Soft Power On wire, to ANY Ground wire.
The Soft Power On wire has Green insulation, and is located in the 24-pin ATX main power cable.
ANY wire that has Black insulation is a Ground wire.
To explain:
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1610NX desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127350
I would like you to scroll down the page, until you come to the motherboard illustration.
(Under the - Motherboard layout and photos - heading)
This illustration represents the motherboard from a top view, and with no hardware components installed.
(No Processor, Ram Memory modules, power cables from Power Supply plugged in, and so on)
At the top right of the motherboard is a small rectangle, with an inscription in it.
(The tiny printing reads - SMSC with LPC47M997NR under it)
Immediately below this small rectangle, is the 24-pin ATX main power cable connector.
Two vertical rows of 12 socket holes.
(Next to it is printed - ATX 1)
Now here is a much better view of a 24-pin ATX main power cable, and the corresponding connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The photo to the far left, shows a better view of the 24-pin ATX main power cable connector, on the motherboard.
(Yours may be an opaque whitish plastic. It also will not be located on the outside edge of the motherboard)
The photo in the middle, shows the 24-pin ATX main power cable not plugged in.
The photo all the way to the right, shows the 24-pin ATX main power cable plugged in, and shows the Green Soft Power On wire.
Also shows the Black ground wires.
The 24-pin ATX main power cable is left plugged into the motherboard.
Looking at the middle photo once more, note how the power wires come into the connector.
This is the Back of the connector.
Each wire ends in a metal terminal.
The metal terminal is approximately 1/2 inch in length.
This means the power wire goes down in the connector pretty deep, before it ends in the metal terminal at the Front of the connector.
I use a wire that is approximately the same size, (Gauge), as the power wires, for the jumper wire.
Strip around 1/2 inch of insulation, from each end of the jumper wire, then twist the wire ends.
The jumper wire should be around 3 inches in length, and bent into a U-shape.
Power supply unplugged from power, insert one end of the jumper wire into the socket hole that contains the Green wire.
(Soft Power On wire)
The jumper wire end is stuffed down into the socket hole with the Green wire, right next to the Green wire. You are pushing the bare stripped end past the insulation of the Green wire, with the intent of touching the metal terminal end.
Insure that the stripped bare wire, is touching the metal terminal end, as best as you can.
The stripped end may have to be longer than 1/2 inch.
(An alternate form of jumper wire is a paper clip straightened out, then bent into a U-shape, with wraps of tape in the middle for insulation. I have used this method also. I just don't recommend it for solutions)
Power supply plugged back into power:
With the one end stuffed down into the socket hole for the Green wire, hold the jumper wire by the insulation, and touch the other end down into ANY socket hole that has a Black wire. (Ground)
Warning!
There may be a spark. You may wish to wear a glove on the hand for the jumper wire.
The voltage is 5 Volts (DC)
Two common flashlight batteries are 3 Volts. (DC. Each battery produces 1.5 Volts)
To me it isn't a big deal if there is a little spark. Wanted to advise you beforehand, so that you would be aware, though.
The Power On button that you push is made of plastic. Located inside it is the Power On switch.
With finesse the Power On switch can be removed, and a new one inserted.
(I use a hair dyer on low heat setting, and move the hair dryer back, and forth to gently soften the plastic, so that tabs can be eased to one side, and the Power on switch removed.
The Power On button/switch assembly can also be lowered, {Removed from computer}, into a bowl of very, very warm water, to soften the plastic Power On button. The switch will be removed, and thrown away. The plastic Power On button is then dried, and readied for the new Power on switch)
(Barring the worst case scenario, if a correct Power On switch cannot be obtained, a Power On switch can be used by itself, and would just hang outside of the computer. Not very aesthetically appealing, or professional, but the computer will work again)
I have found that this generic Power On switch, seems to be a correct substitute for most computers,
http://www.directron.com/atxswitch.html
Ebay may have one in Computers and Networking>Computer Components.
Older computers, used a different method to turn the Power Supply on.
(PSU - Power Supply Unit)
The Power On button pushed against a long metal rod, which in turn pushed against a Power On switch, located in the Power Supply.
The Power Supply in your computer always has a constant 5 Volt standby power, when the Power Supply is plugged into power.
When the Power On button is pushed, it pushes against the Power On switch.
Inside the switch is a convex shaped thin disk of metal.
The 'plunger' of the switch, pushes against the middle of the convex metal disk.
The outside edges of the disk are connected to Ground.
When the convex disk flattens, the middle touches a Positive connection.
This contact is Momentary.
The Power On switch is a Momentary Contact Switch.
When you let go of the Power On button, the disk resumes it's convex shape, and the brief connection is broken.
The Power On switch wires connect to pins on the motherboard.
The area the pins are in, is the Front Panel header.
(A connector on a motherboard is referred to as a Header. The plastic piece on the front of a computer is a Front Panel. Sometimes referred to as a Front Bezel)
To remove the Front Panel to your computer, far enough to easily access removing the Power On switch, the Power On switch wires will have to be disconnected from the Front Panel header, on the motherboard.
So will all the wires leading from the Front Panel, to the Front Panel header on the motherboard.
Looking back at the motherboard illustration, the Front Panel header is located on the very bottom right of the motherboard.
JFP1
(Junction Front Panel 1)
You will note that there are two rows of pins.
Four across the top row, five across the bottom row.
BEFORE (Not shouting) you attempt to remove the Front Panel, it would behoove you to make a drawing, and notes as to where those wires go.
If wires come loose, I don't have a way at present to tell you where they go.
It has been a while since I have worked on this series of Compaq Presario's. The wires from the Front Panel may just end in a single connector, that you simply line up with the corresponding pins on the motherboard, and plug the connector in. (On?)
The connector is oriented, by the pin in the Front Panel header that is missing.
Four pins across the top, with one missing.
Five pins across the bottom.
The connector will also have one hole blocked off, to match the pin layout of the Front Panel header.
The other wires from the Front Panel though, may not end in a single connector.
These headers are for the audio connections on the Front Panel, USB ports, and so on.
I'll await your diagnoses to see if a new Power On switch is required, or a new Power Supply.
If it is a new Power Supply that is required, I will give recommendations, and why, if you wish.
Should you have any questions, I will try to reply as speedily as possible.
Testimonial: "Thank you so much! What a great reply! I really appreciate the detail, references to online manuals as well as the suggestion for where to get parts. Wonderful help! THANK YOU!!!"
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jul 16, 2010
SOURCE: I want to upgade my Compaq Presario SR2150NX PC
Yes of course you can upgrade your Vista PC to Windows 7.
The only thing you have to do is back all your wanted files like movies, pics, docs etc to slave or storage drive. Then you can proceed to install Windows 7. Just make sure you install over the Vista partition if you are going to perform a clean install.
If you just want to upgrade and keep your settings just pop the disc in while you are using the Vista machine.
If you need anymore advice please post back.
Regards.
Anonymous
  • 289 Answers
  • Posted on Nov 06, 2011
SOURCE: Can I run Windows 7 64-bit Home Premium on my HP
or simply install the said windows then after installing it connect to the internet then go to my computer right click on it then properties, then go to device manager then look for the driver that not yet been loaded right click on it then click update driver through the internet be sure you are already connected to the internet before executing this procedure, tnx maybe it helps
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
2answers
1999 compaq desk top replaced windows 98 with bootlegged xp. want upgrad windows 7 but not enough juice
It is highly unlkely this old computer can run on Windows 7.
You can run a Windows 7 upgrade advisor tocheck if your computer is suitable for Windows 7.
Click on this link to download the check upgrade program :-http://www.microsoft.com/downloads/en/details.aspx?familyid=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
I have a persario sr1620nx, the on board video went out, i need to install a video card, but i do not know what type to buy? looking for assistance. please help
Go to this website for specs.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr1620nx/1707-3118_7-31589079.html
There's also an x16 PCI Express slot for users who want more graphics horsepower than the onboard ATI Radeon Xpress 200 chip affords.
1helpful
I have compaq presario v3000 1. i would like to ask can i upgrade my graphics card.i mean do we have the option to upgrade the graphics card? 2. i got my laptop with vista basic installed in...
Windows 7 is superior to XP, in my opinion. If you have 7 there isn't any reason to go back to XP, which is no longer supported by Microsoft in a big way.
I think that the graphics card on a laptop is integrated onto the motherboard in ways such that upgrading to a better graphics card is not generally possible.
It's fun to think about these things, though.
I have a compaq presario 7470 PC which currently has windows 98, Iwant to know how can i update it with windows 7 and how muche it'll cost?
Generally the specs for Windows XP machines are good enough for upgrading to Windows 7 without too much cost.
But, Windows 98 was a bit further back in the history of Windows.
You can go to Microsoft.com and use an upgrade advisor to see if Windows 7 will work on your machine.
And, they'll tell you the cost.
Display Resolution for Compaq Presario Upgraded XP to WIndows 7
not its possible.... that resolution come with the LCD of the laptop and the only way its buying a lcd screen that support more resolution.. Pls click if my solution was helpful
12helpful
I cannot install SP37394(Need this to upgrade to XP SP3 on my HP)
do you have this happen to you?
"A problem has been detected and Windows has been shut down to prevent damage to your computer...
Also how much ram do you have?
2answers
Have Windows ME,seems to be outdated. Do not make software for it anymore. Would like to upgrade to Vista.Can't hook up anything to it. Have to be Vista or XP. Which is better for a Compaq Presario 5000
The Compaq Presario 5000 is not powerful enough to run Vista so XP is your best bet. I assume you have the standard 512MB RAM which will be fine for XP Once you outgrow that you'll need to go for more powerful hardware. By that time the new Windows 7 should have been officially released.
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
