Knob is shocking me
SOURCE: knob not working and some burners not heating
The switch under that knob is bad. It's called an infinite switch. As far as the elements go, first thing to check is for proper voltage (220) to the cooktop. Let me know what you find.
SOURCE: jenn air electric cooktop
first, disable power to cooktop. next, replace either the mangled burner or the entire unit (after initial inspection leads to a logical prognosis)...sorry.
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
