Hi, I have circled the fuse in question. If the fuse is burned, the problem may be due to an improperly wired aftermarket stereo. If you have an aftermarket stereo and this fuse keeps burning, please get back to me.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Usually the brown wire is for illumination. If you have supplied power to this wire some how it will keep these lights on. If you got wiring schematics with the stereo recheck your work.
It sounds like, maybe during the stereo installation, that a fuse was blown. It is a common problem. Check your fuse that runs to your instrument panel. If this is blown, replace it with fuse w/ same voltage. Hope this was helpful... Please take a second to rate how helpful this suggestion was. Thanks and good luck!
