20 Most Recent
Kenwood KDC-MP232 CD Player Questions & Answers
Kenwood KDC-MP232
This is a similar repair, but the resistors you need to reflow solder on ae on the bottom of the circuit board, not the top like the other models. The reference numbers for the resistors are R130, R131, R133, R135, R136, R137, R138, R139, R140, AND R141.
They are 4.7 ohm resistors and should have "4R7" printed on the top of them. They are not as close together as the other model has them, but if you take the board out of the unit you should be able to find them. Put just a touch of solder on both sides of each resistor. This should be plenty to fix this problem.
It is also possible that you may have another cause for this problem, but this is the most likely cause.
I hope this is some help for you. Let me know if you need further instructions.
Dave
6/11/2017 1:56:16 PM •
Kenwood...
Answered
on Jun 11, 2017
I Put two new speakers
Protect means the speakers are drawing too much current. Recheck your installation to make sure the wires are not shorting to each other or to the chassis. If the wires look good, check the impedance of the speakers using an ohmmeter. Anything less than 4 ohms is probably a bad speaker, but compare your readings to the spec on the box. Please let me know if you have more questions, and thanks for using FixYa.
4/29/2011 8:35:23 PM •
Kenwood...
Answered
on Apr 29, 2011
How do I enable the Auxillary option on my
when your car is on, turn the stereo off. you should be able to access a menu somehow when the stereo is off. in that menu, you should have the option to toggle the aux source on or off. simply switch it to on, then turn the sterreo back on, and hit the source button. it should now be ready to go.
2/13/2011 11:25:15 PM •
Kenwood...
Answered
on Feb 13, 2011
My kenwood cd player is
the output ic inside of the deck is probably bad. unless you are good a desoldering and soldering it will need to be repaired by a professional.
1/18/2011 6:15:23 PM •
Kenwood...
Answered
on Jan 18, 2011
