Konica Minolta bizhub 350 All-In-One Laser Printer Logo
d
dinesh Posted on Feb 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have konica minolta bc 250 its giving error c2553 pl help me
Boiken Verli
Level 2:
Habit-Forming:
  • Expert 96 Answers
  • Posted on Mar 17, 2014
Boiken Verli
Expert
Level 2:
Habit-Forming:
Answers
96
Questions
0
Helped
68744
Points
142
Hello it is a image unit problem.
You got your toner/developer ratio out
Magenta will be low as we know.
Then while still in service mode run TCR supply
Re-check ratio % you should be OK
Change magenta image unit
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Jul 14, 2010
SOURCE: i have fetal error code 08H,14H &15H in
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
7helpful
Konica minolta C252 error code C9401
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
26helpful
3answers
Error code c 3452 on ineo 250+
develop ineo 250 machine error comes c3452
how i solve this
1helpful
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
FATAL ERRORCODE:XX
6helpful
Bizhub 250. error c2152
16helpful
2answers
Please help me for the internal error (C-2553)
i have konica minotla bc352 its giving error c 2553 and megenta background
pl help me
5helpful
Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
