AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which wires goes to which post ? Just bought an ao smith 3/4 hp booster motor for my polaris pool cleaner. It has two yellow wire posts. Which do I conect the black and white wires to?
John Prohaska
Level 3:
President:
  • AO Smith Master 1,378 Answers
  • Posted on Jun 14, 2009
John Prohaska
AO Smith Master
Level 3:
President:
Answers
1378
Questions
Helped
689226
Points
3511
It does not matter. Just make sure it is set to the correct voltage your system supplies to it and that you put pne wire on each terminal as the diagram on the side of the motor will show you.
3answers
Hi,i have a AO Smith S# c56a05a19 HP 3/4 ,type C, v 115/230 , Ph 1.0. I need to connect it to 230 volt. , can´t find a Wiring diagram. Can someone please help??
Yes this is an old thread but info is still helpful to those that are searching. Here is one diagram from a 3/4 motor. Be aware that most residential high voltage are 240v. This will have the motor turning a bit faster.
2helpful
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
How do I wire then capacitor on the max e glas ll
if the cap is on top of the motor, one lead on each post. if it's the one in the back of the motor generally the two yellow wires go to one post and the red/whit one goes to the other post. .. now there are to posts on the cap each has 2 or 4 tabs on each (post)
Need to reconnect wiring inside AO Smith Model C48K2N143B4 3/4 HP Booster Pump. It's a 60 Hz 15/7.5AMP unit
that's easy ground goes on the top green screw at about 1 o'clock the others can be ether way see picture .. go to your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_56_42_pm.jpg
1helpful
AO Smith motor #C48l2ec11c3 I need to get a part that goes on the back of the motor, has two wires and one screw. Its plastic with copper bands
Please contact me thru our website at www.arrowmotor.net and be sure to include the info in this post as well as the serial number from the motor. I should have the part you need in stock.
John
How do I replace the capatitor on my 1HP pool pump motor. I have the new part but cannot tell which of the three wires attaches to which terminal.
Please use or contact page feature at www.arrowmotor.net and include your motor model and serial number. I can try to get you the connection diagram. If by chance you have the 2 yellow, one red wire combination, the two yellow go together on either set of posts and the red goes alone on the other set of posts. There is no polarity to a capacitor so it does not matter which set is which, just what wires you pair together.
Looking for wiring instructions for the replacement polaris pump motor. It says it is wired for 240 and I need the configuration for 120. It is polaris booster 3/4 hp pump.
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
