20 Most Recent
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Questions & Answers
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
My pool pump wont start. Makes no sound at all.
Clean the impeller to make sure nothing is clogging it. Then, Take the back casing off of the motor, and there should be a place where you can use a screwdriver to manually spin it. Spin it as you turn it on, and it should start right up. Mine didn't have a problem after they.
