Zebra Symbol MC3190G Handheld Mobile Computer Logo
A
Anonymous Posted on Feb 20, 2014
Not able to select actual count - Zebra Symbol MC3190G Handheld Mobile Computer
  • Official Brand Answer 3,100 Answers
  • Posted on Jan 20, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685093
Points
13487
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Where do I find the stitch count on a Brother Pacesetter PC-8500D
To check the stitch count on a Brother Pacesetter PC-8500D embroidery machine, please follow these steps:
  1. Turn on your machine and select the embroidery mode.
  2. Press the "Machine Information" key on the touch screen.
  3. Scroll down to the "Stitch Count" option and select it.
  4. The stitch count for your machine will be displayed on the screen.
Note: If you have reset the stitch count on your machine, the stitch count displayed will be zero.
I have stripped of ricoh MP2501L 8 times having same error on screen as ' open instructions on right side to solve What is the actual problem. Is it sensors or what.
SETTINGS YOU CAN CHANGE WITH USER TOOLS
General Features Panel Key Sound The beeper (key tone) sounds when a key is pressed.
• Default: On Copy Count Display The copy counter can be set to show the number of copies made (count up), or the number of copies yet to be made (count down).
• Default: Up (count up) Function Priority You can specify the mode to be displayed immediately after the operation switch is turned on, or when System Reset mode is turned on.
• Default: Copier Print Priority Set the print priority for each mode.
• Page 20 "Multi-Access"
• Default: Display mode
• When [Interleave] is selected, the current print job will be interrupted after a maximum of five sheets. Display Contrast You can adjust the brightness of the display. Key Repeat You can select whether or not to use the key repeat function.
Measurement Unit You can switch the measurement between "mm" and "inch".
• Default:
• Metric version: mm
• Inch version: inch
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
Reset error m2
M2 -waste toner box need to empty.
Displayed to indicated that the Toner collect count of the consumables counter has reached the set count.To reset select Count in the Tech.Rep.mode and acces the Consumables screen.Select the count of toner collect and press the clear key to clear the count.Place the copier in the Tech.Rep.mode by pressing the following keys:Stop-0-Stop-1.
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Having opened the top pannel to clean lens, my Laserjet 5000N came up with this error message. "printer error 52.0"
52 is a scanner error, the scanner here is actually a rotating mirror assembly that 'scans' the laser right to left. (as the paper moves top to bottom)
Make sure you did not smudge the lens or move it too far in any direction. Gently use a clean q-tip or equivalent to 'reclean' the lens.
Then, power down, count to 10, power up.
Same error?
Power down. Find green checkmark button, power up, when memory starts to count, press and hold green checkmark button until ready, data, and attention lights all flash. Release Green checkmark button, display should say "Select Language".
Press Down arrow once, display should say "Cold Reset".
Press select and wait for a reboot to complete.
If you still have the error, then you have a physical problem and will need a repair tech to fix it.
1helpful
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Reset maint counter
Page 3-17 of IBM's service guide
1helpful
Oracle date problem
All dates are actually date-time fields - if you don't specify the time, Oracle defaults to midnight. To filter date-time specify the date-time string as a formatted field like this:
select count(*) from mytable where dttm > to_date('20080610181907','YYYYMMDDHH24MISS');
This is the date June 10, 2008 at 6:19:07 PM as an example.
Top Zebra Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
