20 Most Recent
Oracle 10g Database Standard (ODBSEONUPP0) Questions & Answers
Quickbooks
Have you tried reinstalling your Quickbooks? From time to time Quickbooks does have errors related to their updates. The 1st step I would suggest is back up your company data file, and then uninstall, shut down, and then reinstall. Then you can import your data file back into Quickbooks. This should resolve your issue.
How to convert sdf file in xls file ?
SDF file is a compact relational database also called a SQL server database. Designed for the application that runs on mobile devices and desktop.
If you only want to access SDF files in Excel sheets then you can see your SDF files in SQL Server or Visual Studio.
Whst is the difference between .mdf,.ldf &
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
What is a .sdf file? How to generate a .sdf file using ms access?
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and
Visual Studio 2005 to build, test, deploy, and manage applications for
users. Databases of this type can be accessed directly as a datasource,
e.g., from Visual Studio 2005, or from SQL Server Management Studio. As
such, they can be passed around with programs or projects, although
they are mainly used for embedded applications. The file includes all
necessary code points to access the data, and so does not require an
instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
Charging Black and Decker Simple Start
okay people... this is a long one, but I just did it for two units that were having this problem and it worked both times.
The problem is the unit sat on the shelf and doesn't have enough power to operate its charging cycle.
Take an extension cord and plug in the outlet charger while you also plug it into your cigarette lighter... now attempt to charge it (you will hear the familiar alarm). Now, turn on the LED light... after a short time, turn off the light and the unit will begin to charge regularly. You can then use one of the chargers to finish the job.
By doing this you are providing plenty of power to the battery while the light drains it at a slower rate... kinda forcing the battery to condition/cycle; it's just allowing the battery to take the charge. Hope this helps.
Formulas
You may want COUNTIF if you're specifying criteria. For instance, if my prices are found in b3 to b7, here's a formula that will find all those that are less than 6 ($6.00):
=COUNTIF(B3:B7, "<6")
If you're using multiple criteria, such as you want to find all the prices that are greater than $5 and less than $8, the following will accomplish it. (The ABS gives you the absolute value of the result, in case the smaller number is first.)
=ABS(SUM(COUNTIF(B3:B7, ">5") - COUNTIF(B3:B7, "<8")))
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
How to run tally4.5 in winxp
if you have cd, then install manually otherwise proceed online install which ever is easier for you! have fine!
12/17/2009 10:31:33 AM •
Oracle 10g...
Answered
on Dec 17, 2009
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
How can i use tally 4.5 in windows xp
If it is not supported in XP, then you should change your operating system or change the version of Tally that matches the system you already have.
I need Oracle 10g cd
You need to contact the manufacture of this product to obtain a legal copy or key. This posting is in violation of Fixya TOS. For more information read Terms at the link provided at the bottom of the page.
Microsoft outlook
lokya to check if you have new email, you have to press send/receive tab on your toolbar, that would start the process of synchronising your emails. You'll see your new emails and drafts from your outbox will be send.
If that has helped you please press solved.
