Apple iPhone Smartphone Logo
Posted on Jun 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I add an appointment to my iPhone and then synch it with Outlook, the appointment shows up 8 hours earlier in Outlook. The other way around (add an appointment to Outlook) the appointment is 8 hours later in my iPhone. Both my desktop computer and iPhone have the correct time and the correct time zone. Any ideas?
Steve Brown
Level 3:
President:
  • Apple Master 688 Answers
  • Posted on Jun 10, 2009
Steve Brown
Apple Master
Level 3:
President:
Answers
688
Questions
Helped
394089
Points
2264
One of the problems is that a web server can be overseas and an end user can be far far away.
One suggestion after checking current answered questions is to turn the time zone support off.
turn the Time Zone Support off.
Settings-Time&Date-Time Zone Support off
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
My Dell Axim X5 pocket PC reverts to wrong date
Duh... I figured out that my PC had the date set a month ahead! Not sure how that happened. The Axim was dutifully synching up w/ the wrong date, and so the November appointments didn't register. Thanks for checking.
Appts on iPhone do not synch to computer
you need to set your preferences in itunes to sync properly
Sync iphone calendar with outlook 2003
hello!
try the ff:
Reset Sync History
- Open iTunes
- On the Edit menu, click Preferences.
- Click the Syncing tab.
- Click the Reset Sync History button.
disable third-party add-ins
- Open Outlook 2003
- From the Tools menu, choose Options.
- Click the Other tab.
- Click the Advanced Options button.
- Click the COM Add-Ins button.
- Determine whether any third-party (non-Apple) add-ins are present in this list. The add-in "iTunes Outlook add-in" is made by Apple and can be left alone.
- Deselect the checkbox for each third-party add-in in this list.
- Click OK.
Reinstall the iTunes software
Attempt to sync content in a new Windows user
- From the Start menu, choose Control Panel.
- Open User Accounts.
- Select Create a new account and follow the instructions to complete the account setup process.
Note: Make sure you only use standard ASCII characters for the new user name.
- Once the new account is created, choose Log Off from the Start menu.
- Log into the newly created user account.
Once you are logged into the new user account, create a few test contacts and/or calendar events in your compatible application of choice and attempt to sync that data to your iPhone.
Appointments off by one hour after DST
did you get the update for the new DST shift that happened a week early this year?
Appointments synching in wrong time zone
Is the incorrect time on the computer you are syncing to then?
56helpful
9answers
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
1helpful
Time difference
Try to reset your time in your phone and try synching
Sep 11, 2005 • Palm M100
Casio pocket pc calendar doesn't show appointments that were syncronized from outlook: If I sync with outlook, the appointments I add on the Casio E-125 show in outlook, but the ones I add in outlook...
The Menu: VIEW - Categories option at the bottom, has all categories checked off. However, the logic dictates that it will only show the categories checked off, and if any appointment (appointments being made in outlook are not categorized) with no category would not show in the pocket pc. The logic written into the software, is, if no categories are checked off, then it will show ALL appointments. It would be nice if there was an option in the category view menu to SHOW ALL, but there isn't. You just have to uncheck all the categories.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
