20 Most Recent Palm Treo 755p Smartphone Questions & Answers
2answers
Unlocking my sprint palm treo 755p
do you mean locked to a network /provider? or locked meaning security usercode locked?
11/2/2014 2:34:01 PM • Palm Treo 755p... • Answered on Nov 02, 2014
Phone wont turn on
Did either of you recently install the update for 755p from Sprint? Soon after I installed it (within a few days) my phone started that as well. I spoke to tech support at Sprint and they were zero help. I went to my local store and explained to the tech person there exactly what was happening and told them I thought the Sprint update caused it. The rep. agreed and they replaced my 775 with a new one as he said it could not be fixed. I think because I told them the problem was caused by the update then they were obligated to fix it (or I least I made them believe that).
Hope that helps.
1/2/2013 7:26:27 PM • Palm Treo 755p... • Answered on Jan 02, 2013
2answers
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
12/17/2011 11:15:05 PM • Palm Treo 755p... • Answered on Dec 17, 2011
Screen not working property -showing purple lines
Try taking it to the nearest maintenance
5/14/2011 1:18:40 PM • Palm Treo 755p... • Answered on May 14, 2011
Red/green/blue boxes how do i
could you explain what the problem is, that doesn't make much sense to me
2/27/2011 1:29:09 AM • Palm Treo 755p... • Answered on Feb 27, 2011
How can I stop my screen from freezing or locking
pls bye me
2/23/2011 6:06:46 AM • Palm Treo 755p... • Answered on Feb 23, 2011
Screen says access powered and
you can tr y a cold restart (erases all info on machine but it may delete whatever is holding it up. for directions on a total reboot http://www.notsofaqs.com/faq_pg17.php
12/17/2010 4:15:34 PM • Palm Treo 755p... • Answered on Dec 17, 2010
I did the reset but it will only go to confirm
enter the language you want, then follow instruction...John
12/7/2010 12:42:38 AM • Palm Treo 755p... • Answered on Dec 07, 2010
When you turn on Treo you get an error message
"rom Image" is reffering to the operating system on the phone, this is common when rooting android phone but not sure on treo, check treo website for "rom update" may have to plug ur phone into your computer to doit. hope this helps
10/26/2010 10:49:35 PM • Palm Treo 755p... • Answered on Oct 26, 2010
2answers
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
10/18/2010 8:56:38 PM • Palm Treo 755p... • Answered on Oct 18, 2010
Screen stuck on Access powered
Just had the same problem and had to do a hard reset. Of course, Sprint tech support told me that I couldn't do that if none of the keys worked but when I held down the red start-up button and kept it pressed as I re-insert the battery and then answered yes to removing all old data, it worked for me.
10/18/2010 4:51:16 PM • Palm Treo 755p... • Answered on Oct 18, 2010
How do i do a hard reset on a Palm 755p
take the battery out. press the red button down and without releasing it, put the battery back in while still holding the red button down. It's a little awkward but works.
9/29/2010 2:31:58 AM • Palm Treo 755p... • Answered on Sep 29, 2010
I forgot the password to
0000
9/29/2010 2:27:32 AM • Palm Treo 755p... • Answered on Sep 29, 2010
8answers
Master Reset TREO 755p
I have had this same problem from day one with my 755p. The issue is that the phone still thinks there is a headset plugged into it-even though there isn't one. I have heard it is because of poor welding. If you have the monthly protection plan you should be able to take it into a Sprint store and have them give you a new phone (I have done this twice now). For the meantime, you can stick a paperclip into the headset hole and toggle the switch. This is only a temporary fix. I have not heard of Sprint/Palm actually fixing the problem-it is probably cheaper for them just to give out new phones. I hope this helps...
9/27/2010 2:48:54 AM • Palm Treo 755p... • Answered on Sep 27, 2010
How to activate my internet
what activity
8/23/2010 11:25:21 AM • Palm Treo 755p... • Answered on Aug 23, 2010
Need unlock code for verizon
Thank you for the information. Here is how to disable the Verizon data network without affecting your calls:
  1. Goto Preferences ---> Network -----> Disable Internet Options.
If this does not work please let me know. There is one other work around that you can try.
8/22/2010 3:17:54 AM • Palm Treo 755p... • Answered on Aug 22, 2010
I took my Treo 755P apart to dry it and upon
That is your mic. It is supossed to sit on the bottomleft side of the green board.
8/16/2010 7:42:01 AM • Palm Treo 755p... • Answered on Aug 16, 2010
2answers
Phone does not ring enough before I can answer
I needed to increase the rings once before, all you need to do is call up your carrier, and ask them to do it.
Best Regards,
Sam
Was this information helpful? Please rate it!
7/21/2010 1:18:46 AM • Palm Treo 755p... • Answered on Jul 21, 2010
Palm Treo 755p Smartphone Logo
234 questions posted
Popular Products
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Treo Palm
  • Treo Palm
Most Popular Question
palm treo smartphone upon reboot gets
  • Computers & Internet
