hi Loria, are you sure its a 3 bleep then 3 bleep then a pause then repeats ?
this is very important, if that is the case it's a controller failure.
3. bleeps and then 2 bleeps
means a issue with the brake ,,, check the scooter not in freewheel when you turn it on ,, if you can push the scooter move the lever otherwise it won't work, now there could be a issue with the connection between the frame and the rear axle where they come apart , try removing and refitting ..
I'm not familiar with accenta plus alarms but if your motion detector is picking you up then your panel is beeping sounds like the motion is programmed incorrectly.
The 5-beeps indicates you are in free-wheeling mode. If the free-wheeling brake disengage lever is in the correct position then you likely have a bad brake switch or bad brake coil assembly.
Verify free wheel lever is in correct position and Replace the bad component if necessary.
