Got mongoose and a schwin scooter. Neither runs properly. There is juice and the wheels turn, but wont get up and go with a rider. Loses power quickly and fades but will still turn back wheel at high speed when back end is lifted up. How do I know if its just needs new battery or if its motor/clutch problem? Currie motor and clutch on both scooters.
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
when the switch is turned of and then back on the same problem occurs. the motor runs full speed and then stops
