20 Most Recent
Pride Revo 4 Wheel Scooter Questions & Answers
Batteries not charging
1 dud batteries?
2 dud charger? Borrow another
3 has a 10 Amp fuse hidden under the floor mat and inspection hatch below blown. Pride don't want to tell you about thevtwo fuses down there.
How do you takshroud off the motor of pride revo?
You are almost certainly going to have to lift the seat off its post as you do with other Pride scooters. This is not light and it can be sticky and need tobe wiggled off - get help.
The shroud is usually velcroed into place and can easily be detached. Lift it off and put safely to one side.
Why is my scooter running slow?
Hope its this. Batteries fully charged. You should take to dealer. I bent my go lever. I bent it back alittle. There is little switches under the cover, they can moved. Lever is not make proper contact
Can the throttle be switched to left thumb for
No Well maybe If you remove the console cover and see how the throttle is mounted to the tiller. If the throttle pot and handle are screwed to the tiller with two screws you might be able to unscrew the throttle assembly and flip it upside down letting you use your left thumb to push on the throttle. Unique problem because if you can't flip it then you are stuck pulling the throttle reverse side outward to make it go forward. Hope this helps you might even have to flip the throttle lever ( take it off the throttle pot and flip it and reattach to the pot stem) so it will fit back under the console cover. I dunno for certain but you can try
The rear axle on my fortress 2000 scooter moves
there is a bearing inside pin roller this get no grease unless pulled apart and serviced so if this has not been done the bearing is most likely worn out take apart and find bearing number very small ### so wash in solvent to see it go to auto parts store and order new 1
NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:1) try it woth the shroud off the motor using.2) look for dirt around the switch. 3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.Let me know how you make out.Dan
Noise on back axle
Is the noise like a stone stuck in the tyre? If so, I think you have a dry axle, a common problem with Pride scooters and easily rectified. Simply remove the rear wheels, apply grease to the axle shafts, and re-fit the wheels. This should solve your problem. If it's a different type of noise, the problem may lie within the transaxle which would unfortunately involve a costly repair or most likely a replacement transaxle.
St Anthony's Nursing And Rehabilitation Center
St. Anthony's Nursing and Rehab Center is a leading provider of compassionate, high-quality healthcare services dedicated to enhancing the well-being of our residents. With a rich history of delivering exceptional care to seniors and individuals in need of rehabilitation, our facility is a cornerstone of the community. At St. Anthony's,we believe in the power of personalized care, combining cutting-edge medical technology with a warm, family-oriented approach. Our experienced and dedicated team ensures that each resident's unique needs are met, providing a comfortable and nurturing environment for their journey to recovery. We take immense pride in offering a brighter and healthier future to those we serve, embodying our commitment to exceptional healthcare. Source: https://sanrc.com
Where is the fuse on my Jazzy pride mobility scooter
the fuse box location may vary depending on the model of the scooter. However, it is usually located under the seat of the Jazzy scooter. You can access it by unscrewing the two bolts that hold the seat in place. Once you remove the seat, you should see a black box with a white label that says "FUSE". The fuse is located inside this box.
The latch won't stay latched on pride jet 3 ultra
If the latch on your Pride Jet 3 Ultra power wheelchair won't stay latched, there are a few potential causes and solutions you can try:
- Check for obstructions: Inspect the latch mechanism and the surrounding area for any obstructions or debris that may be preventing it from latching properly. Remove any obstacles and ensure that the latch can move freely.
- Adjust the latch position: Sometimes, the latch may need to be adjusted to ensure a proper fit. Check if there are any adjustable components on the latch mechanism and try repositioning them to achieve a secure latch.
- Tighten or replace the latch: If the latch is loose or worn out, it may not hold securely. Check if there are any screws or fasteners that can be tightened to secure the latch. If tightening doesn't solve the issue, you may need to replace the latch with a new one.
- Seek professional assistance: If the latch continues to have issues or you are unsure about making adjustments or replacements yourself, it's best to contact Pride Mobility or a certified technician for further assistance. They will have the expertise to diagnose the problem and provide the appropriate solution.
