The high temperature alarm or the red light indicator came on because the internal temp is high. This means that the temperature inside your appliance is still too warm. Keep your freezer/frig door closed and the light will go out in a few hours and you'll then be able to adjust temp or keep it as it was before defrosting.
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting
Need to check the temp to make sure its cold enough.. thats what that alarm is for
