KitchenAid JavaStudio 14-Cup Programmable Coffeemaker - Onyx Black Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No brew, error 2
My Kitchenaid coffeemaker model 5340 will not pull up the water to brew and shows Error 2. How do I fix it?
Anonymous
Level 2:
  • Expert 145 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
145
Questions
0
Helped
154318
Points
404
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Is there a way to reset a KitchenAid KCM1204 back to factory settings?
You will need to investigate the reason that it's not heating. Check the element and the thermal fuse that should be on the element for continuity. If the fuse has failed replace it and try it again. If the element has failed you may be looking at buying a new coffeemaker.
20helpful
2answers
Err2 display and no brew
The KitchenAid website states if it shows Err1 Err2 or Err3 try re-setting the power to the unit if it returns there is a problem with the electronics and Err4 is a stuck button. The Err2 is a heating element falure. Unfortunatley it may cost you more to fix than a new one. If it is less than a year old they may repair it under warranty but after a year your on your own. If you call them and complain that you have read a lot of other people online have the same problem they may repair it for you...Hope that helps.
Kitchen aide coffee maker model #KCM534 shows an error 2 on the screen and we can't et it to work. please e-mail me at [email protected] with an answer . We have unplugged it and done everything we...
Cuisinart coffee on demand
There are a couple of possibilities. I would try an unconventional decalcifying process - let 1/2 a caraffe of distilled white vinegar and 1/2 caraffe water sit in the reservoir for a full hour with the coffeemaker unplugged. At the end of the hour, plug the coffeemaker back in and turn it on - once a small amount of vinegar and water brews through, turn the coffeemaker off. Let sit for an additional 20 minutes. Then turn the coffeemaker back on and let the rest of the vinegar/water brew thorugh.
If the machine doesn't take the vinegar/water at all, call Cuisinart and find out if your are still in-warranty. If you are, get the machine replaced. If you are out of warranty, you can remove the bottom of the coffeemaker (difficult), and look at the bottom - likely you will see a loose hose. You can get a Ace Hardware or True Value Hardware salesperson to find an adhesive that will put it back together, or get a generic replacement hose - original parts would not be available except by buying a broken Cuisinart in the same model.
My two cents.
-Tha Mp3 Doctor
1helpful
How do i fix ERR2 on my Kitchenaid coffeemaker?
Kitchenaid Coffeemaker
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few moments.
If the code does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Coffeemaker does not brew
I put vinegar and water in and it was fixed.
7helpful
5answers
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
49helpful
2answers
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
