open the snanner lid in printer powering on then the cartridge cradel will move to middle then open the both color and black cartridge and look the down side of the cartridges you will look some glazed white part .that is the print head which is metallic thin plate.when electric apply on it it heat and melt the ink and create some vaporize condition in the cartridge then air flow from the cartridge and spray the ink on paper.
You should service this printer.May be it is dirty or not free move .It has scanner lock/unlock position .May be it lock. you check it . Thanks Tareq Bin Mostaq Bangladesh
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve.... before that pls. check your cartridge unit...
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
You may use this a copier but usually, all in one printers used as copier take a long time to produce print outs. It isn't as robust as It usually scans the pages first (duration is the same as scanning a document) then prints it out (duration is the same as printing a document from a PC).
In my experience with our multifunction printer, a single page can be photocopied in about 45 seconds to 1 minute. It isn't as robust as photocopying machines.
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
