Model #f9k1001v3
SOURCE: how to install my belkin router with no cd or manual
It is very easy to install the router without the CD.
you can do it manually.
first make sure that your computer is online through the modem.
If it is then open the router set up and change the settings on the router.
Click here for step by step info about router set up
SOURCE: trying install belkin n150 router.setup router and
Try the following:
1. Make sure your PC is connected to the router directly and the LAN ports are lighting up
2. Reset the router
3. Reset the network adapter on your PC (or just restart the PC)
This should ensure that you are connecting on the LAN port.
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
