20 Most Recent Belkin N150 Enhanced Wireless Router wireless router (S7506885) Questions & Answers
Setting up for use on laptop
ay6dz0yqzpfvaaaaaelftksuqmccconnect the cable on the yellow jack and the other end to your pc.
1/27/2013 7:03:24 AM • Belkin N150... • Answered on Jan 27, 2013
I have a Belkin wireless router- I haven't
if you had a cd that you installed it should be in the program.
Look for a Belkin program on your computer, the password should be there, you can change it after you've found it.
9/23/2011 11:54:34 PM • Belkin N150... • Answered on Sep 23, 2011
Hi I have just purchased
you can download the drivers right to your computer. Here is the link:
http://en-us-support.belkin.com/app/answers/detail/a_id/2752/~/f6d4050---n150-enhanced-wireless-usb-network-adapter---software-and-drivers
This product has multiple versions. Please check the version number on your adapter to ensure that you load the appropriate driver.
7/5/2011 7:44:55 PM • Belkin N150... • Answered on Jul 05, 2011
How to get internet on ipod touch with belkin
1. tap on the settings.
2. Then under Settings, tap on WIFI.
3. Then turn on WIFI.
4. Once you turned on your WIFI, you will be able to see your wireless network.
5. Tap on you wireless network, if it will ask for your password, kindly input your wireless password, after doing so, you will be connected.
6/4/2011 1:15:52 PM • Belkin N150... • Answered on Jun 04, 2011
I have 3 computers on a wireless network and can
Hi! put your routers dhcp on to give ip addresses to all computers.
5/28/2011 12:44:36 PM • Belkin N150... • Answered on May 28, 2011
The connection to the internet
It Seems like it is an issue with the firmware
Click here to download the latest firmware
4/27/2011 10:16:29 AM • Belkin N150... • Answered on Apr 27, 2011
Hello we forgot our password for our wireless
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
4/20/2011 3:34:35 AM • Belkin N150... • Answered on Apr 20, 2011
I have followed the steps in your installation
Step 1 : Connect Router - Notebook ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
2/25/2011 7:38:57 PM • Belkin N150... • Answered on Feb 25, 2011
I have a new belkin n150 when i conect to the
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
2/21/2011 12:58:51 AM • Belkin N150... • Answered on Feb 21, 2011
HI, I need help in
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
Regards
TOM
1/25/2011 6:40:38 PM • Belkin N150... • Answered on Jan 25, 2011
I need to unlock and
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
If you need more help come back.
Post / thumbs / testimonial are welcome!
1/16/2011 11:47:00 PM • Belkin N150... • Answered on Jan 16, 2011
Hi, I got a Belkin
PLEASE TEL ME THE MODEL NO SO I CAN FIND THE FIRMWARE VERION FOR YOUR PRODUCT .. U CAN FIND MODEL NO BELOW THE ROUTER - STARTING WITH F5D OR F7D
1/11/2011 2:36:45 AM • Belkin N150... • Answered on Jan 11, 2011
I own a belkin n150 router. i've used ti on my
Your wireless card in her laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (security key) is in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
12/29/2010 1:56:57 AM • Belkin N150... • Answered on Dec 29, 2010
I have a wireless internet connector for my xbox
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
12/23/2010 12:43:13 AM • Belkin N150... • Answered on Dec 23, 2010
Found my router with 1 green light on, reset with
12/12/2010 8:31:11 PM • Belkin N150... • Answered on Dec 12, 2010
I'm trying to get my b/g/n capable router out of
Hi friend, In this case i would recommend you to select the Security type as WPA and then try to enter the secure password and try save settings
12/11/2010 2:31:00 PM • Belkin N150... • Answered on Dec 11, 2010
Can't use n wireless settings to it's full potential
Range (distance from modem/router to computer) is shorter on higher speeds -- N signals won't travel as far through your home as G. Walls greatly reduce range. Move the computer closer to the modem/router and see if you don't get higher speeds. Then you can decide if you need to relocate the modem/router closer to the computer. The question is, why is Wi-Fi speed important to you? Your G speed is already 10x - 20x your Internet speed. Wi-Fi speed only matters if you're doing a lot of file transfers between devices inside your network. You may be trying to solve a problem you don't have.
4/22/2017 3:32:30 PM • Belkin N... • Answered on Apr 22, 2017
Belkin N150 Enhanced Wireless Router wireless router (S7506885) Logo
29 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
N Belkin
  • N Belkin
Most Popular Question
setting up use laptop
  • Computers & Internet
