Low Download speed may be due to various conditions such as,* If your Internet connection is shared with others on your LAN and they are using up all the available bandwidth. Tell them to knock it off* Your ISP may be limiting your P2P traffic via some method of packet
shaping. Call up the ISP and inquire if they do anything with P2P
traffic.* Check whether you haven set up your third party firewall or internet monitor software correctly.* Your computer might have been infected with malicious software which altered the low level network settings of your operating system.* You need to optimize your operating system for your current connection speed. First, close all P2P applications. Next run the
DSLReports TweakTest. Once you have optimized it, then run a speed test at
www.ScanMySpeed.Com This will give you a good idea what your maximum download and
upload speeds are. If you're getting within 10% of your connection
speed, that's the best you can get! If you are having trouble with your connection, and it relates to packet loss, excessive latency, or Internet or ISP congestion, running the
Line Quality Test may help find the cause
