Most likely you have merely blown a fuse so check that first.
Next check the wiring to the trailer connection to see if anything has rubbed through to a bare wire
Not all relays are the same so you may have installed the wrong type.Consult the manual (get a copy of RAVE online) and/or contact one of the reputable parts suppliers stating your model and VIN - that will ensure you get the correct replacement
SOURCE: Blower motor stopped working
most common is the blower motor resistor or "module" going out. but if you have 12volts to the resistor the motor should work on "HI" but not on any other speed. if it doesnt work at all, you might have a bad motor. just to be safe id replace both. neither one is too hard to replace. three 5/16" bolts for the motor and two 5/16" for the resistor they are both under the glove box
SOURCE: Indicators not flashing on Audi TT
i believe the audi uses two relays for the turn signals and hazzard lights so it would appear the turn relay has failed. it should be located under the dash near the steer column.... seems to me me they have some shielding under the dash so it may be hard to get to.
Sounds like for one reason or another that alternator is putting out too much voltage to battery. Did mechanic check to see if new alternator was rated same or close to old one, as in amperage rating? Pulley on new alternator same size? You'll need to get it to another mechanic who knows what he's doing, obviously that guy wasn't too concerned with curing your problem. That's why I was hoping you had a voltage reading when running.
SOURCE: have no indicators, hazards work,no fuses are blown
somewhere along your steering column behind the dash should be a module called the electronic flasher module. This unit controls your turn signals and works separate from your hazards. Odds are the unit has gone bad...
