My hp all in one has a 5oo g hd that crashed so i have a new hd with win 7 preinstalled works fine however i keep getting this error this copy of windows is not genuine so what do i need to do to resolve this Best regards Mike
Try installing the OS that shipped with the computer. If it is an HP OEM version that you are installing on the HP computer for which it was designed then you should not have any problem. Otherwise, you need to buy a license from Microsoft, or the recovery disks for your computer from HP.
Testimonial: "Hello there I have got it fixed the solution was rather easy i just contacted hp and they informed me that even though i had a different hard drive i could still use the product number that was on the sticker on the bottom of the machine I did just that and yes it worked didnt have to reinstall anything"
SOURCE: Vista Ultimate Error 0xc004f061
if you have purchased legal copy of Vista, you will be having a Part Number on the Vista DVD. Call Microsoft Tech Support and provide them with this Part Number. they will get a new product key. This will work for you.
SOURCE: This computer did not pass genuine windows validation test.
It really is a nuisance for users with genuine products. This has also occurred to many people with MS Office 2003. It could however be caused by someone installing XP or Office that used a Corporate License that will require updating in a different way and not via the MS Auto Update procedure.
You can simply uninstall the MS update check that does the validation or return you machine to a known good state via the system, restore function. Look at your system history to see which update you need to uninstall and avoid reinstalling next time you get the option. So turn off auto updates and then make sure you control which updates are applied.
Also call the store where you bought the system if they are still in business.
SOURCE: Microsoft detects that my pc has not genuine copy of Windows 7
Remove Windows & and reinstall you old software. Or buy a genuine copy of Windows 7. You can also install Linux, which you can get for free (Ubuntu will always be free.)
Hope it helps
SOURCE: Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
SOURCE: Windows 7 build 7600 This
Hi There, Best to follow the instructions as per the Microsoft Website ... http://windows.microsoft.com/en-US/windows7/Windows-7-activation-error-invalid-product-key This will assist and verify your windows licensing.
