Canon Speedlite 580EX II TTL Flash Logo
A
Anonymous Posted on Feb 07, 2014
Wireless king ttl flash only fire low light - Canon Speedlite 580EX II TTL Flash
Yes I have a user manual
Does the manual explicitly state that you can use the TTL setting with the flash in wireless mode ?
1helpful
Sca 346/2AF M don't recognized on Nikon D40 like TTL
Film Cameras were NIKON TTL Nikon Digital Cameras are I-TTL. These two systems are not compatible. Film cameras did the metering in real time. When enough light struck the film the flash was turned off. With I-TTL the flash fires a quick flash and the image is quickly analyzed and the flash fires again to take the photo. With digital it is delayed and it is NOT in real time. The camera only looks at a few pixels to make the analysis fast. I hope this helps
Hello there. It seems that the Sigma EF-500
John, there is a difference in sync times between film and digital flash. It's taken the third party manufactures a little time to catch up so there is a lot of "film" flash units out there. I'm understanding that the Sigma flash doesn't fire at all which is pretty amazing I would have thought it would fire just not at the correct time. This flash isn't a total loss because it can be used wireless with a slave unit for fill or even a main light triggered from a mini transmitter on the camera hot shoe. Here is a link to an e-Bay auction to see what I'm saying.
http://cgi.ebay.ca/Wireless-Flash-Trigger-Transmitter-Receiver-4-Canon-/230537528202?pt=Camera_Flash_Accessories&hash=item35ad1b838a
I use this type of system for a location shoot, there are no wires and I can set up and balance my lighting to each set with no more dark backgrounds hope this was a help
I've mislaid my manual for my Metz 54. I haven't used it for a while and can't remember how I set the thing to shoot in ttl with my Fuji S6 Pro. When I'm in ttl mode on the flash the camera doesn't fire....
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
Can I use it wirelessly with a canon EOS 40D
Yes you can but it won't TTL and you will need to fire it from or with a slave/light cell. This will make your system more like a studio set up. You will need to increase/decrease the light intensity using different modifiers for special effects. My portable/location set up uses 2 Vivitar 283's, a Canon 533G, Nikon SB 15 and a Canon 420 EX all fired from little flash slaves. here is an e-Bay reference link
http://cgi.ebay.ca/Flash-Slave-Trigger-Hot-Shoe-Sync-Adapter-Sensor-US-/110405132832?pt=LH_DefaultDomain_0&hash=item19b4a8a220
Hope this was a help
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Sb 600 under exposure.
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
Cannot get to work right either TTL or as wireless remote
This one got me too. I assumed it wouldn't need the built-in flash if it was a wireless remote. I still want to know why this is is so. If it needs a pre-flash to set exposure, surely it can pre-flash with the remote SB600?
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
