Error 59.99 - If I replace the Drum it works fine, no error so it is not the T2 clutch I took the drum apart and put it back together. Everything fits perfectly, just perfect. Any ideas why the drum might be causing the printer to throw this error?
Many drums have a chip with a lifecycle. You may need to replace the chip if you dont want to replace the drum.
SOURCE: HP LaserJet 2840 Printer
For Flexer and Guest - The Imaging Drum Assy is the 5-th consumable for your printer. U can buy it as well as any toner cartridge. U can find it in the front of the 4 toner carousel with a green plastic cover. Push it to the back of the printer and pull it out straight up. The new one has orange stripes and plastics that you should remove. The Imaging Drum's life is about 20k pages (black with 5% coverage) and 5k page (colour 15% coverage)
SOURCE: HP LaserJet 2840 replace drum
Have you checked status for the drum using toolbox or solution center? Try clean the contacts on drum and opposite HV pins in printer.
SOURCE: error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
59.99-T2 Clutch error: Check the cable
connections to the DC controller. If the error
persists, remove the imaging drum and
check the clutch. If the error persists,
replace the T2 clutch. If the error still
persists, replace the DC controller
(seeRemoving the DC controller
Any chance you got a bad drum unit? It could be binding which would cause this error.
