SOURCE: 19 "lcd gateway monitor will not power on.
Is this a Gateway FPD1960 monitor? If so the power supply inside of it died. It is a common problem with these. I repair the Gateway FPD1960 monitor so if you want to trash it let me know. You can contact me at sure-power(at)nc.rr.com
SOURCE: Acer 1711 monitor won't power up
power supply of the monitor is the culprit.Generally defective electrolytics in primary section of Power supply.
SOURCE: Monitor not receiving a signal
I have these monitors, didn't you get another cable in the pack which has a vga plug on the end? I have had trouble with those converters, try a DVI to VGA cable
SOURCE: Monitor loses power randomly.
Is your monitor a CRT or LCD type. For CRT type information follows. In most cases your simptoms indicate a problem with the High Voltage or blanking circuits. Caution the High voltage can be as much as 40,000 volts and even unplugged from the wall the picture tube can continue to hold voltage (enough to hurt you). Do you here a snapping sound from the back of the crt. If you do the high voltage is shorting out and the protection circuit is turning off the high voltage. If you do not here sparking another possible cause is a faulty capacitor in the protection circuit or the flyback (high voltage transformer). Unless you are educated in electronic circuit repair this one is probable beyond your curren knowledge level. You can try taking the back off and cleaning out all the dust, but remember to stay away from the red wire that goes to the picture tube. Use only non metal cleaning tools. Good Luck
Nssms
SOURCE: The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
P.S. it is a FPD1530 Manufactured in March 2004
