Lexmark X4270 All-In-One InkJet Printer Logo
Posted on Oct 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark x4270 not printing
I have purchased new ink cartridges. but unable to print info when a fax comes thru or when making copies. i did run an alignment page. i received a message that there was an alignment problem. i also ran a "clean print". the color prints on the alignment page but shoots out blank paper when a fax comes through or copies. what should i do?
NOEL
Level 3:
Top Expert:
  • Lexmark Master 8,606 Answers
  • Posted on Oct 27, 2017
NOEL
Lexmark Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322469
Points
68630
5 Related Answers
Geraldine Watts
  • 390 Answers
  • Posted on Feb 14, 2008
SOURCE: blurry printing fro lexmark x4270
May be too much info blocking up print memory. Before printing off sites, make sure you clear print queue and slect printer friendly versions. Check to see if your printer has a work online or offline setting in preferences too.
Anonymous
  • 3940 Answers
  • Posted on Jul 14, 2008
SOURCE: lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
priya sabharwal
  • 7 Answers
  • Posted on Dec 04, 2008
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Sanath Kumar V
  • 684 Answers
  • Posted on Jan 19, 2009
SOURCE: printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
Anonymous
  • 169 Answers
  • Posted on Jun 19, 2009
SOURCE: Alignment error on the HP L7680
you need to reset the printer using the # and the number 6 buttons and while holding down the buttons plug in the power cord.See if it works else try the same with # and the number 9.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Unable to print or make copies even after replacing ink
Not enough info. What, when, etc., etc., etc. OEM or refill cartridges? What was error msg before replacement. What is msg now? Did you clean contacts?
When I make copies or transmit a fax, it makes a 3/4" black line down the left side. I have cleaned ink cartridges and contacts but does not help.
The line is probably not from the ink cartridges or nozzles (assuming regular printing doesn't streak). Streaks on copies and transmitted faxes are usually due to dirt or problems on the scanner unit. First clean the flat bed of the scanne. If you have an automatic document feeder, clean that.
Clean with a lint free cloth moistened with a little water or glass cleaner. Make sure no foreign objects are in the ADF path or on the glass. For pictures see the Lexmark support site: http://support.lexmark.com/index?page=product&linkSelected=node0&locale=EN&userlocale=EN_US#1. Then enter "streak on copy" - the solution comes up in a pop up.
If the streak is shrinking, then copy a blank white piece of paper to identify where to clean further. Try scanning another page with a small mark on it. (These are particularly helpful for cleaning the ADF.)
If the mark occurs when you print, then check if you have a damaged cartridge or other ink that has spilled inside the printer.
I hope this helps.
My LEXMARK x4270 won't print. I replaced both ink cartridges and when I tried to print or copy, the paper comes out blank.
Did yo remember to remove the protective tape from the cartridges. Are the cartridges in their correct locations and are they firmly seated in their receptacles?
I have a Lexmart X4270 Printer Copier. I replaced the print cartridge but it still doesn't print.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Purchased lexmark x4270 all in one scanner copy fax product, set up two days ago, will not print. All lights are on, when i try to print from computer, paper goes thru but no info prints. HELP!!!!!!
If the unit is new, look for anything that may have been placed in
or around the carriage to protect it during shipping. Also the tape
across the ink cartridge may still be in place. If so, pull out the cartridge
and remove the tape. That's what my prob was when I first got my
all in one.
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
Won't print or copy
If printer was idle for weeks, even if "relativly new", run cleaning in control panel/printers and faxs/maintanence.
If still inoperative contact manufactor, see about support or warrenty claim. Not to bash lexmark but, the cheaper of their printers work the best, the costly ones like the all-in-one I bought from them, was used for three months, I hated it and threw it out.(cost $300.00)
Blurry printing fro lexmark x4270
2answers
Wont print text
Clean your black printheads tobyss. Remove cartridges. Using cotton buds and proper cleaning solution, clean where the cartridges sit in, until no colour comes away. Press a babywipe (unscented) firmly on bottom of cartridge where ink comes out. Replace cartridges. Print again. Run printers own cleaning solutions too.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
