When you wind it manually (forward or clockwise) it winds the mainspring. Only need to watch it 5 or 6 times if it's completely stopped you wearing it will do the rest. If you going to get a automatic winder get one that will wind in both directions. It will give a few revolutions clockwise and then we'll go reverse counterclockwise.
Hope this answers your questions thank you.
The only way that makes any sense is if there is something loose inside the watch possible the battery plate or battery are moving when you are moving. The back will need to be removed and the battery plate checked. You will need to have the watch checked at a jewelry store or watch repair shop. Thank you i hope this helps a little !!
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
You should be able to wind it manually. Pull out the crown to the winding position and wind fully. With any automatic watch you should do a manual wind periodically.
Hello
These are the things you might need about the watch.
1. Turn the crown clockwise while it is in position 2 to manually wind the watch.It will stop if it has not been worn out or put in a watch winder for roughly two days.
2. Pull the crown out one notch to position 3 to change the time.Turn the crown clockwise to move the minute hand.
3. Push the crown back into the watch while turning it clockwise to return the crown to position 1.The crown should be tight to ensure the watch case is waterproof.
4. Operate the stopwatch and chronograph function by pressing the button located above the crown on the 3 o clock side of the watch.Stop the stopwatch by pressing the button again,Reset the stopwatch by pressing the button below the crown.
BEST OF LUCK
If it has only recently gone stiff then it sound like a trip to the dealer for repair.
It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
Could it be that you need to pull out the crown to wind it?
