20 Most Recent
Jaeger-lecoultre Reverso Duoface 2711410 Wrist Watch Questions & Answers
The watch seems to stop when I wear it - fine timekeeper if not worn!
The only way that makes any sense is if there is something loose inside the watch possible the battery plate or battery are moving when you are moving. The back will need to be removed and the battery plate checked. You will need to have the watch checked at a jewelry store or watch repair shop. Thank you i hope this helps a little !!
I have broken watch that
Do you have the model number. That would help you to make some speculations or comparing the recent cost or repair.
Thanks!!
Vintage 1940. Doesn't run. Numbers on back of case
It might be worth having the back of the watch removed to see if there is anything engraved on the movement.
You might find that cleaning the watch gets is going, although the advice of the watch repairer should be asked for on this, as it might be very worn and in need of new parts which are unlikely to be available.
If it works and there is information on the movement, you might be able to get some information on the watch from the maker. Visit their web site (www.jaeger-lecoultre.com/) and make an inquiry, giving them all the information that you have.
An interesting problem!
Good luck.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
How do I set time.? No manual, remote does not work.
- Buttons on the Device: Look for any buttons on the device itself. Sometimes, there are buttons that allow you to navigate through menus and adjust settings directly on the device.
- Trial and Error: Try pressing different buttons on the device to see if any of them bring up a menu for setting the time. Look for buttons labeled "Menu," "Setup," "Clock," or similar.
- Long Press: Sometimes, pressing and holding certain buttons on the device can activate different functions. Try pressing and holding various buttons to see if it triggers a menu for setting the time.
- Google Search: If you know the model number of your Ultech device, try searching online for the manual. Many manuals are available for download from manufacturer websites or other online sources.
- Contact Manufacturer: If you're unable to find the manual online or if you're still having trouble setting the time, try reaching out to Ultech's customer support. They may be able to provide you with guidance on how to set the time on your device.
- Replace Remote Batteries: If the remote isn't working, try replacing the batteries. Sometimes, a non-functional remote can be as simple as dead batteries.
2/28/2024 9:57:13 AM •
Watches
Answered
on Feb 28, 2024
